The MP3car.com Store
Thread Tools Display Modes
Old 04-18-2005, 10:21 PM   #16
My Photos: (0)
Quote:
Does anyone have xenarc connected for a long time to the car wiring without any problems ?
I've been running the same Xenarc directly to 12V power for 1year now without any issues. My setup is basically a 1.5 Amp fuse with a relay in the middle. The power is unregulated directly connected to the Cig +12 lead. The relay is turned on off by the Radio Headunits auxilary amp turnon output.
If you want, I guess you can regulate some to eliminate any high vltage peaks that occur, but I wouldn't go crazy about it.
Mark
Website: http://www.geocities.com/daracerz83/
Car'Puter Project
- Xenarc 700TSV
- MSI RS482M-IL Mobo + AMD Turion MT-32 (25W)
- 1x 256MB Corsair XMMS DDR400
- M2-ATX
- Belkin 802.11G W-Nic
- Garmin 15H GPS
- WinXP SP2 (NLited)
DaRacerz is offline   Reply With Quote
Sponsored Links
Old 04-18-2005, 10:36 PM   #17
adidas445's Avatar
Vehicle: 2002 Saturn SC2
My Photos: (0)
what about just hooking the screen up to the switched 12V and then using a switch to power it when the car is off? would that work? i need an answer pretty soon please...but would this be a bad idea seeing as the fact that the screen wouldnt keep any of its settings once the car is off? dang it, i need a way around all this without buying an opus or something like that...any help?
EDIT: after looking for a while i found this...
http://www.itx-warehouse.co.uk/Produ...?ProductID=197
would that work for what i want it to and where can i get it from a US distributor?
thanks....
2002 Saturn SC2
system install progress....
[----------*---] 85%
Kenwood KDC-828 - eD 6500s - two eD 9.2s - eD 13kv.2 - eDead sound deadening - custom ported box - clifford matrix 10.5x
adidas445 is offline   Reply With Quote
Old 04-19-2005, 09:35 PM   #18
My Photos: (0)
My screen turns off all the time as I cut the power when I pull the key. To answer that question, theres two parts. First, each time it detects a signal or signal change, it will do an autosync to the resolution. Two, if you cut the power, it will still retain the Backlight setting on the monitor and couple other things
The problem thats been noticed is that the Brightness settings don't get saved when you cut the power to the unit, and guess the same would go with the contrast.
Mark
Car'Puter Project
- Xenarc 700TSV
- M2-ATX
- Garmin 15H GPS
Old 04-20-2005, 12:02 AM   #19
Curiosity's CarPC Specs
Curiosity's Avatar
Vehicle: 98 Trans Am
My Photos: (3)
Sorry to change the subject from the previous post, but I'm thinking it may be better to run the Xenarc directly off the car because it has an internal regulator. If you run it off regulated 12V, it will only have a maximum of around 11.3V coming out if it's own regulator.
XPort 1.26 -GPS port splitter, logger, and USB device resume fix
Curiosity is offline   Reply With Quote
Old 04-20-2005, 05:06 AM   #20
PORTUGAL's Avatar
Vehicle: 2001 VW BORA TDI
My Photos: (0)
I contacted Gain and they said it was safe powering the monitor directly into car 12v....
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
PORTUGAL is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
12V, 5A Regulated Car Adapter Alta Power Supplies 6 03-03-2005 12:02 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 05:38 PM
pre-built Xenarc carputers any good? Jackboot General Hardware Discussion 11 07-07-2004 09:44 AM
12v Xenarc Power Supply StuBoy LCD/Display 7 02-01-2003 07:40 AM
Xenarc Meta FAQ Skippman LCD/Display 0 08-23-2002 03:11 PM
Sponsored Links
Ad Management by RedTyger
