The MP3car.com Store
Thread Tools Display Modes
Old 04-18-2005, 04:47 AM   #1
PORTUGAL's Avatar
Vehicle: 2001 VW BORA TDI
My Photos: (0)
Xenarc straight into carīs 12v ?????
I have the xenarc indash screen and its suposed to accept 11-24v, so i conected straight to the car wiring, and it worked great, it was in fact brighter than when i tried regulated 12v (from opus )....
Who else has their xenarc conected dirctlt to the cars 12 v?
Can i damage my monitor in the long run using this method ?
Im asking this because my headunit also reads dvdīs and i wanted to turn on the monitor (for av use) without turning on the car pc....
Thanks in advance
Here in Portugal we have great weather, lots of brunnets, party a lot,drink a lot....
http://img138.echo.cx/img138/896/bannerjoshua5dy.jpg
PORTUGAL is offline   Reply With Quote
Sponsored Links
Old 04-18-2005, 04:56 AM   #2
MaleBuffy's Avatar
Vehicle: Peugeot 307 CC
My Photos: (0)
Use a FUSE ASAP!!!! Its ok to have it directly on the 12V but as I said, you have to fuse it or you might experience a very bad moment!
MaleBuffy is offline   Reply With Quote
Old 04-18-2005, 05:00 AM   #3
BeaverWise's Avatar
Vehicle: 1989 Camaro RS
My Photos: (0)
What size fuse would you recommend?
VIA MII 10000 - 512MB Ram - Dual 2.5" drives, Xenarc 700TSV, Panasonic CW-8132-B, Opus 150, Audigy 2 NX, PowerMate, IOADR1610 10 Relay card
BeaverWise is offline   Reply With Quote
Old 04-18-2005, 05:54 AM   #4
PORTUGAL's Avatar
My Photos: (0)
The indash monitor already had a fuse.
12v(unregu)-----fuse ------Monitor.
Does anyone had bad experiences conecting the monitor this way ?
Old 04-18-2005, 05:57 AM   #5
Tainted Love
Cris's CarPC Specs
Cris's Avatar
Vehicle: 2006 Renault Megane
My Photos: (0)
I don't think it will be a problem since it was written on the monitor itself.
Any pics?
Epia M10000
Travla C137
Opus 150W
7" MM400 V2 Touch Screen in Custom Dash
7" MM400 VGA Monitor
7" Monitors in Custom Headrests
Slim DVD
BU-303 GPS
iDrive Griffin Powermate armrest
USB Wireless LAN
Cris is offline   Reply With Quote
Old 04-18-2005, 06:03 AM   #6
PORTUGAL's Avatar
My Photos: (0)
No pics yet, full install in the will be saturday.
Took a pic of the monitor conected to the psu, you can se the wires and the fuse
Crappy photo
Old 04-18-2005, 06:16 AM   #7
MaleBuffy's Avatar
My Photos: (0)
1 A should work fine since the Monitor uses less juice!
Old 04-18-2005, 06:17 AM   #8
MySQL Error
Scouse Monkey's Avatar
Vehicle: Pug 306 & BMW 325i
My Photos: (0)
Portugal, your screen will be brighter because you are feeding 14V+ from the car alternator into the CCFL inverter. Now the specs say that this should be ok as it can take up to 24V but remember your cars supply is unregulated and may have all sorts of nasties in it - espectially when your start your car! Normally tour car stereo etc is cut when the car starts but if you connect direct from the battery you won't have this protection.
Running form a higher voltage should be ok but prlease do it from some sort of regulated supply as Xenarc controllers cost about $160! I have actually wondered about running a Xenarc off a laptop DC-DC at about 15V but as it runs the screen brighter I would assume the inverter is being fed directly and over powering your CCFLs will shorten their life.
As for fues, the Xenarc site rated the screen at 12-24V 1A so a 1.5A fuse should be sufficent but you may find you need something a bit higher. put a nice accessable fuse in and if it blows and there is nothing wrong try a slightly higher one.
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 04-18-2005, 06:38 AM   #9
PORTUGAL's Avatar
My Photos: (0)
Maybe i will conect it directly to my opus and save troubles in the future, the problem is that i wanted my screen to be powered and leave the pc off sometimes when i wanted to see movies with my dvd headunit.
Does anyone have xenarc connected for a long time to the car wiring without any problems ?
Old 04-18-2005, 06:43 AM   #10
Raw Wave
Gobby's CarPC Specs
Vehicle: Pug 306 XSi
My Photos: (0)
Get hold of an ITPS or similar and power the TFT Directly from that. Thats how I am now powering my LinITX screen - works perfectly
Gobby is offline   Reply With Quote
Sponsored Links
Old 04-18-2005, 06:54 AM   #11
PORTUGAL's Avatar
My Photos: (0)
I didnt remember itps ....
Thanks uk mp3car
Old 04-18-2005, 07:06 AM   #12
MySQL Error
My Photos: (0)
why not get a cheap 1-1.5A DC-DC converter used for portable DVD players etc and wire that up to you ACC line?
Old 04-18-2005, 07:16 AM   #13
Raw Wave
Gobby's CarPC Specs
My Photos: (0)
Thanks uk mp3car
Also means your OPUS has more juice to power the CarPC for later additions :-)
Old 04-18-2005, 09:54 AM   #14
Vehicle: Toyota Rav4 2000
My Photos: (0)
well, I went to Radioshack, and bought a cig. adapter that has the same dc plug as my xenarc. and I know all cig. adapters have a fuse in it.
nl4jy is offline   Reply With Quote
Old 04-18-2005, 10:00 AM   #15
MySQL Error
My Photos: (0)
Is it regulated??
Make sure the power is the right polarity. I seem to remember the xenarc is not the normal polarity.
Sponsored Links
vB code is On
Trackbacks are Off
12V, 5A Regulated Car Adapter Alta Power Supplies 6 03-03-2005 12:02 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 05:38 PM
pre-built Xenarc carputers any good? Jackboot General Hardware Discussion 11 07-07-2004 09:44 AM
12v Xenarc Power Supply StuBoy LCD/Display 7 02-01-2003 07:40 AM
Xenarc Meta FAQ Skippman LCD/Display 0 08-23-2002 03:11 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
