i have a 4runner, so suv stuff
carpc is in passenger rear wheel well
amps are up front, xenarc up front
i have 4g to driver seat to distro block, 3 8awg out (2 to amps up front, 1 to trunk)... this goes to a distro block to the inverter, dssc, relays, etc. Grounds for pc case, inverter, dssc feed to a distro block then to chassis
dssc goes to front w/2 14g wires, one splits to remote turn on for amps and 1 goes to usb hub. ground from this usb hub is problem one
other 14g wire goes to xenarc and problem in question
i was gonna do a molex extension to the front but no where to put the dvd rom, so i'll just leave it in the back
i dont know if running a 15ft wire from the xenarc and usb hub to the rear ground is ok. the amps ground to 2 separate points up front (they are like 8 inches long of 8g wire).
the reason i did this with the ground on the amps was because i have a center console and i tried running wire under it and it pinches the wires and no juice. otherwise i'd do a distro block there and send the shizzle to that...
signal wires go up passenger side, power up my side
thanks
[4Runna]
next - wifi
