Old 04-20-2005, 12:59 PM   #1
LCD Video cable length?
Is there a limit to the length of a monitor cable the one from the puter to the display. I put in a 10' extension so i could relocate pc to trunk.. Monitor says no signal... I hooked up a house monitor with normal cable and it works fine.... everything for touch screen worked fine till i put in the extension... I've checked all connectors from lcd to puter and they are tight.... If i hook lcd up direct with no other cable it works too... I have 2 extensions totaling 15' between dash and puter... only thing i can think is cable... I'm stumped
LOstBoy is offline   Reply With Quote
Old 04-20-2005, 01:50 PM   #2
Change's Avatar
That's odd. I've got a 15' extension cable that works fine...could be the cable isn't very high quality and the signal levels are degrading too much for one monitor? Don't know, all I can do is fling out wild guesses...
Change is offline   Reply With Quote
Old 04-20-2005, 01:53 PM   #3
hanzacra's Avatar
Did you try hooking up the house monitor with all of the extensions in place? If that worked, I'd double check the extension connections or buy a single extension rather than stringing things together. I have a 10' triple-shielded monitor extension cable and it's never had any problems.
EPIA M10K, Lilliput 7", 512MB RAM, 40GB 2.5" HD, M1-ATX, RoadRunner, FreeDrive, BU-353 GPS, Sabrent TV Tuner
hanzacra is offline   Reply With Quote
Old 04-20-2005, 07:13 PM   #4
I found a video signal booster in town so im gonna try that tonight if not ill have to puzzle some more.
Old 04-20-2005, 07:29 PM   #5
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Why two extensions? Keep the install as simple as possible. With two extensions, you have twice the likelihood that either a cable doesn't work or that the signal voltage drops too far to work properly.
I'd advise what hanzacra said, try the known, good house monitor with the extensions in place. See if that's the problem.
I'd also advise going with just a single longer extension, rather than two.
I've got 16 feet on my monitor with no ill effects.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Extending your laptop's LCD cable: FAQ Yuriy LCD/Display 14 09-09-2008 09:48 AM
7" Roof Mounted Video LCD MP3_TJ Classified Archive 4 02-14-2005 03:55 PM
FS: 25' CAT5 IDE Cable & 3.5" PVP Player! CHEAP! 1300mer Classified Archive 9 08-13-2004 02:47 PM
Extending LCD cable CoyoteBoy LCD/Display 3 05-27-2004 01:32 AM
Kiosk parts, Ram, 12.1 LCD, 8mm Video recorder CDesigns Classified Archive 0 05-25-2004 02:27 PM
