Old 04-24-2005, 06:35 PM   #1
sux89 is on a distinguished road
XENARC Monitor Proprietary Connector Size Problem
Already Searched.........
I just got my new Xenarc 700tsv and i am mounting it on top of my dashboard. I am mounting in a way that will look very nice, and like it was "supposed to be there".
Well, anyway, since its on top of my dash.....I need to cut some holes for the monitor wires to pass through.....problem is I'm not going to drill and inch diameter hole just to fit a cable through.
So, is there any suggestions? I though about taking the plastic off form around the connector, but noticed that would only shave about 3 mm of.........is there any cables out there that have like a small "quick release" connector on them that are for the Xenarcs? ANY suggestions are appreciated, because I just don't want to have a huge hole in my dash for a tiny cord. Thanks
sux89 is offline   Reply With Quote
Old 04-24-2005, 06:47 PM   #2
Change's Avatar
Change is on a distinguished road
Is there a seam between two parts of the dash you could separate enough to pass the connector through? You could "notch" out one edge of the seam for the cable itself and just pry the seam open to shove the connector through.
Change is offline   Reply With Quote
Old 04-24-2005, 07:10 PM   #3
Banned
xdjxklusivex's Avatar
xdjxklusivex will become famous soon enough
that should work good just drill a hole the size of the cable so it does not pinch it when u remove the screwdriver or shim or whatever ur using to split it open
xdjxklusivex is offline   Reply With Quote
Old 04-24-2005, 08:54 PM   #4
No...I have a 2004 VW GTI and the whole top dash is one single piece...no crevices or cracks......my only option for the wire routing would have to be through the top of the dash...anywhere else would look plain silly
Thanks for the comments....is there any other suggestions?
Thanks again.
Old 04-24-2005, 09:25 PM   #5
Change's Avatar
Ouch. Can you take a few pics of your dash for us? One straight-on facing the dash, one elevated looking down onto the dash (to see from the edge all the way to the windshield)...might be able to get a few ideas from that.
Old 04-24-2005, 09:36 PM   #6
Yeah......but it'll have to wait until tommrow.....its too dark right now. Thank you guys...and keep ckecking back for the pics.
Old 04-24-2005, 09:43 PM   #7
ukchris's Avatar
ukchris is on a distinguished road
Not sure how it would reattach, but you could cut a piece out, notch it, place the cable and put the piece back in. For example cut a 1.5" square out of the dash, notch it to the cable size, stick the plug through the 1.5" hole and stick the whole piece back in. May still look messy as you reattach though, I suppose you could cover it with somethng neater if needed...
Just a thought.
ukchris is offline   Reply With Quote
Old 04-24-2005, 09:54 PM   #8
Change's Avatar
Ooh, true, could get one of those dashboard cover things.
Old 04-24-2005, 10:40 PM   #9
Hmmmm.... I dunno......the point of the matter is just drilling THAT BIG of a hole is kind of nerve racking.....especially since my dash is one piece and would cost a TON of money to replace if something screwed up...I am thinking that if I do have to drill a hole that big, I will get a rubber grommet the size of the hole I drill...with an INSIDE hole of the grommet being the size of the cord. It would finish it off quite well. Does anyone know if there is an "extender" cable with the xenarc male connector on one end and then the female on the other....with a smaller connector in the middle of the cord? Here's a text pic:
XENARC*********SMALL CONNECTOR*******XENARC
If I had that cable, I could attatch one end to the factory Xenarc cable, drill a hole for the smaller connector, feed that connector through the hole, and then attach the last connector to the Xenarc. Get it?
Thanks for all your help everyone!
Old 04-25-2005, 02:48 PM   #10
Well, no pictures everyone. My camera memory card is broken. Anyone else have any suggestions?
Old 04-25-2005, 02:59 PM   #11
nl4jy is on a distinguished road
you can be gutsy and actually cut the xenarc wires and pass it through your rubber gromet and reattach it wire for wire on the inside of the dash so it won't look ugly.
nl4jy is offline   Reply With Quote
Old 04-25-2005, 07:12 PM   #12
Does anyone have any pics of the wire cut open? Is this going to take mad soldering skills, because I know how to solder but am not an expert at it. Thanks.
Old 04-25-2005, 07:30 PM   #13
hd54321's Avatar
hd54321 is on a distinguished road
You will have to solder 20 different wires - it is a 20-pin cable. You could just strip the wires from three ethernet cords, shield the wires by wrapping them in foil and securing the bundle of wires with tightly wound electrical tape.
-HD
hd54321 is offline   Reply With Quote
Problem with Xenarc TS bluehcc LCD/Display 1 01-19-2005 01:13 AM
Blurry Xenarc Problem Lord_Pall LCD/Display 9 12-24-2004 09:26 PM
Xenarc 700YV Problem Sivion LCD/Display 0 12-04-2004 06:46 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
pre-built Xenarc carputers any good? ayclens General Hardware Discussion 11 07-07-2004 10:44 AM
