Need help on extending the Lilliput cable
Hi all,
I'm in the process of moving my carputer from the glovebox to the trunk, and I need help on where and what kind of cable I need to buy to feed the signal from the EPIA M mobo to the Lilliput on the dask.
I've read the "everything about the Lilliput" and found:
"Inputs
SVGA, RCA Composite, & VGA
If you want to extend the video/touchscreen breakout cable (the one that gives you your VGA plug), use a "9 Pin Mini-Din" cable. This may also be referred to as a 'bus mouse extension cable'. Don't confuse this with a normal PS/2 keyboard or mouse extension cable, they don't have enough pins and have a different shape inside.
Example cable: http://www.computerplug.com/cable_m...us-ext-tech.htm"
However, the computerplug offers only the 6' cable, and I need longer than that. I couldn't find anything on Google either.
If you've done this before, please share your experience and where did you buy your cable at.
Thank very much.
