Old 04-27-2005, 01:21 PM   #1
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
What can i do to stop my lilli from dimming?
My lilliput dims when the subs hit, just a little annoying! What can i do to correct this? Is there a capacitor i could add to it or would i need to add a farad cap to my subs to prevent it? Any other suggestions?
Old 04-27-2005, 01:36 PM   #2
fantomas's Avatar
fantomas is on a distinguished road
any of these...
1. turn the bass down
2. upgrade the electrical system
3. i assume you're using the egg to power the lilli....power it of the power supply
the problem lies within your car's electrical system. a farad cap will just put more strain on the alternator. so that might work, but you'll have to end up replacing the alternator anyways.
rebuilding carpc... kinda..
fantomas is offline   Reply With Quote
Old 04-27-2005, 02:00 PM   #3
Banned
xdjxklusivex's Avatar
xdjxklusivex will become famous soon enough
i got 3200 watts bumpin to my subs only and my lilli does not dim and i dont even have a cap! check ur connectors in the back bump some music if it works then :-D if not then :-( try gettin a cap then
xdjxklusivex is offline   Reply With Quote
Old 04-27-2005, 02:03 PM   #4
Terminal flasher
I've already upgraded the alternator and use a yellow top battery. I am using the egg and its connected to a distrib. block which runs an 0 gauge to the battery. Running it to the power supply would require running a car length power wire... at that small of a gauge wouldnt that reduce its efficiency?
Old 04-27-2005, 02:30 PM   #5
Mad Ad's Avatar
Mad Ad is on a distinguished road
as others are telling you, a few farads of cap is not a solution, the web is full of arguments about why not to bother, at best its a band aid for a poor electircal system, at worst its another load that you do not need.
As for wire gauge, you *could* get away with 20awg, since your lookinag at barely 1A along the line, however as you correctly note, you may suffer line loss over 15 feet (boot to console) with thin wires, 20AWG would lose about 0.4V over that distance, however using between 16 and 10AWG, that drops to just 0.1V across 15ft, and better than 10AWG the loss at 1A is negligible.
Mad Ad is offline   Reply With Quote
Lilli only *half* broken. silencery LCD/Display 0 04-04-2005 03:00 PM
Lilli ghosting. Searched and still need help maxxell LCD/Display 1 03-24-2005 04:01 PM
Lilli 7" XP monitor type Won't sync 800x480 BMVEE LCD/Display 3 03-24-2005 09:46 AM
Delorme Street Atlas 05 quick review cash_Money GPS 7 12-13-2004 08:31 PM
Getting a stop message. carpcnoobie General Hardware Discussion 1 05-12-2004 12:16 AM
