Old 05-02-2005, 04:25 AM   #1
BrianMay's Avatar
EEPROM problem solved on a lilliput
A few days ago I installed new usb drivers to try to fix the hibernation issue (I can't..not even with devcon) and after a day or two my touch "puffed"...while trying to callibrate I kept getting the same eeprom error...PANIC...let's search mp3car.com...solution: send it back...needs new controller...PANIC...too expensive and too many days without carpc...Then my Portuguese brain decided to go for a very simple and almost always useful solution...RESET the screen...voilà, it works like a charm!!
I guess it's time to call MythBusters...another one has been solved...
BrianMay is offline   Reply With Quote
Old 06-21-2006, 05:06 PM   #2
Muito bem
camolas is offline   Reply With Quote
Old 06-21-2006, 05:11 PM   #3
My man uses Levitra.
Peoples's Avatar
what do you mean it "puffed"?....did you reset it with the remote?
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 06-21-2006, 05:29 PM   #4
BrianMay's Avatar
Camolas: somos os máoires carago
Peoples: I mean it stopped working. I reseted it in the menu...but I guess you'll be able to do the same with the remote, not sure 'cause I've sold it and I'm now using a k-301
Virando costas ao mundo
Orgulhosamente sós
Glória antiga, volta a nós!
Old 06-23-2006, 05:26 AM   #5
coucouillu's Avatar
could you explain what exactly you did for reset it?
Thank you.
coucouillu is offline   Reply With Quote
Old 10-24-2006, 10:29 PM   #6
How to reset Lilliput when eeprom error occurs during calibration
These instructions work for my model (8.4" touchscreen )
Press Menu key on front of Lilliput frame
Press the > key three times to select the Misc. Control
Press Meny key
Press the > key three times to select the reset
Press Meny key
This causes the screen to reset and it won't work until you reboot your system.
This fixed the error
"Access EEPROM fail!! Please check again."
when I first tried to calibrate it.
BTW, I've had this unit for about 20 minutes. Thanks to those who posted on this topic before - helped me get past first hurdle.
Also, my unit beeped every time I touched it (making me think that the PC was not happy). This appears to be the default setting for the touchkit. To turn sound off, open the touchkit configuration utility and uncheck "Touch Down" check box on the Settings tab.
rac3pm is offline   Reply With Quote
Mac Mini and 8 inch Lilliput USB Problem..HELP! shreddie MacCar 7 04-18-2005 12:41 PM
Lilliput power supply problem davinder Power Supplies 5 01-18-2005 08:47 AM
Another Lilliput problem jjh221 LCD/Display 8 11-07-2004 11:32 AM
Inverter with Toughbook - humming problem solved petemillis Power Supplies 0 11-02-2004 01:12 PM
lilliput and quality problem mrzigzag LCD/Display 0 01-18-2004 02:30 PM
