Old 09-11-2008, 05:37 AM   #136
filecon's Avatar
filecon is an unknown quantity at this point
Guys, all that I know is that I have a GL701 and that when I kill off the ignition, the screen will close and go in the unit. When I connect the accessory on again, it does nothing unless I hit the power button. I would expect that once the ignition is connected the screen will pop out.
Oh well. just have to live with it I suppose.
filecon is offline   Reply With Quote
Old 09-11-2008, 06:01 AM   #137
Fama's Avatar
Fama is an unknown quantity at this point
You will need to change how that has been wired up....
The power cable for your screen should have positive and negative. Take the positive cable and wire this to the ACC cable of the car ( ignition on) and negative to ground.
This will now work with ur ignition switch and once the key is of the screen will be on standby.
Hope this helps...
Fama is offline   Reply With Quote
Old 09-11-2008, 06:25 AM   #138
filecon's Avatar
Hope this helps...
Fama,
thanks for your input but no good. By doing what you suggested, once you kill the ignition, there is no power to bring the screen in and it remains vertical.
I even attempted killing the battery power after the screen has gone in and then powering both the battery and acc power simultaneously to no avail. I might have to do some soldering.
Old 11-30-2008, 02:16 PM   #139
monty9991 is an unknown quantity at this point
guys, is this going to work on EBY701?
monty9991 is offline   Reply With Quote
Old 12-24-2008, 11:06 AM   #140
spainderman is an unknown quantity at this point
Work too with the new GL701-TV-C‏ but now is more easy, all edits are with menu, when u write the 588998 a new window are opened with lang and all hidden configurations.
spainderman is offline   Reply With Quote
Old 06-14-2009, 08:42 PM   #141
archangele is an unknown quantity at this point
I tried it with the GL701. But the power modes don't seem to be working. It always does auto power on.
archangele is offline   Reply With Quote
Old 07-02-2009, 05:21 PM   #142
BlackStealth is on a distinguished road
2.5 years later I made another attempt at getting Auto Power on enabled on my 8" widescreen lilliput (model 889GL-80NP/C/T). I couldn't get into the factory menu at all until I removed the battery from remote control.
Step 1 - bootup carpc to provide VGA signal.
Step 2 - disconnect battery from remote control and plug back in.
Step 3 - disconnect power from back of monitor and plug back in.
Step 4 - power on monitor by pressing button on monitor (do not use power on button from remote).
Step 5 - wait 2 seconds and on remote press 588998 (approx 5 seconds to key those in)
Step 6 - wait for underscores and on remote press 1290210
Step 7 - on remote press 5 to exit
Step 8 - power off and you're all set
It took about 3 attempts before I got in.
BlackStealth is offline   Reply With Quote
Old 11-10-2009, 09:53 AM   #143
keithbrown is an unknown quantity at this point
Hey guys I lost my manual...the red rca is the reverse cam rca right...can anyone tell me what each color rca does...thanks...damn manual is somewhere, just cant find it.
keithbrown is offline   Reply With Quote
Old 11-14-2009, 11:53 AM   #144
blaxer is an unknown quantity at this point
I have a brand new 629GL-70NP with DVI and for the life of me I cannot get the 588998 code to work. Has anyone else gotten this to work with this newest DVI version of the 629 ??
blaxer is offline   Reply With Quote
A different way to Auto – Power – On your lilliput intense LCD/Display 32 05-05-2005 11:49 AM
HELP! lilliput wont power up fenderbender LCD/Display 2 03-02-2005 04:35 AM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Power for the lilliput zmann LCD/Display 2 12-04-2004 01:57 PM
ATX auto power on jumpoint General Hardware Discussion 5 01-25-2000 03:56 AM
