05-18-2005, 06:53 PM
#31
Tried all the methods with my monitor and none worked  . The monitor its a older model, bought april / 2004.
Sorry I cant report the model number because to do so I would have to remove it from the dash.
It has the 9 pin connector.
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status --> Lilliput Installed (not indash yet..)
BraveCar 2.5
05-19-2005, 12:40 AM
#32
for those of you who are having trouble. Try turn on your carputer and the screen is bright enough to see.
05-19-2005, 03:22 AM
#33
uh?
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
05-19-2005, 04:35 AM
#34
Banned
woooooooooohoooooooo worked on my lilliput ill get u guys the model number tommrow its like 1 40 am im sittin in my garage in my car like an idiot but wooohooo this is pimp! thanks !!!!!!
05-19-2005, 09:04 PM
#35
Hi everyone! I only registered to submit my model and inform you that the code is working. :-) I've been lurking for a month or so and EVERYTHING can be found by smart searching. For a month, every question I had has been previously answered by someone. Great community, people. Although hard to keep track of, there are hundreds of posts every day....
About the coding: worked like a charm from the first try. My monitor looks like this:
http://www.mp3car.com/store/images/v...lil7t_logo.jpg
...model is 619GL-70NP/C/T, native resolution is 800x480 and it's serial number is 61980705B0047.
Hint to everyone having trouble with entering code: try playing with the main menu (press MENU button on the remote) and navigating through it (up/down arrows, MENU is confirmation of selection) to get a sense of how long to press the button and where to aim the remote beam.
05-20-2005, 02:23 AM
#36
It ain't easy being a green moderator
Location: Steps out the front of Henson's workshop or Sydney
the codes work just fine on mine.... model is a 629GL-70P/C/T. What Armen said about the factory mode on the menu also happens on mine. As he said, just disconnect the power and reconnect and then you can get back into the factory setup.
Chat on the mp3car channel on IRC
Server: efnet Channel: #mp3car
No irc client installed? Go to http://chat.efnet.org/. In the channel drop down box select "other" and type in #mp3car.
05-20-2005, 03:24 AM
#37
Banned
my model number is 619GL-70NP/C/T and it worked fine for me!!!
05-21-2005, 11:17 PM
#38
My man uses Levitra.
sweet mine worked too thanks Anointed. I've got the same one as Gore-. It seemed for me however that the input screen was missing a dash....so I just typed in 127010 and then I got the menu header/footer that digitalww was talking about....at this point auto-on was working.
PC Components:
My work log
05-26-2005, 09:14 AM
#39
Jippy
The codes worked also for mine Lilliput 7" LCD 619GL-70NP/T
thanks for sharing this wonderfull option with us!
05-26-2005, 10:29 AM
#40
Tainted Love
Do you think it culd work on the Linitx screen? It has the same screen as the Lilli, even the inverter is Hitachi.
05-26-2005, 10:38 AM
#41
Tainted Love
F***, the remote control doesn't have numbers on it, I have to get a Lilli remote and see if that works with the Linitx screen.
Btw, I have my screen opened up, should I look for a SN in there if you thiunk it would help?
05-26-2005, 10:51 AM
#42
No it wouldn't help.
I didn't see a list with SN ranges for what type / production date screens the hack works.
Iknow that your linitx screen is almost the same. but I doubt that it have's the same firmware than an orgininal lilliput screen. maby you can also get your screen into the factory setup screen with another combination thats possible with your IR-remote. send an e-mail to linitx with you question...maybe they have an answer.
05-29-2005, 02:50 AM
#43
i have a 629VT and it works!  always wanted to have this thing auto-on but was too afraid to try the soldering hack. thanks Anointed!
05-31-2005, 06:20 PM
#44
Thanks for the code. I have a 7" lilliput, not sure what model, I think it's a 619 (purchased June 2004). Looks like that, but with clear buttons. My "factory setup" version is 311 033 000. And i only had to input 6 digits, not 7. Works great.
06-01-2005, 05:59 AM
#45
Version is 311. The remaining 6 digits show the current settings.
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
| Thread Tools |
| Display Modes |
Linear Mode
