Old 07-22-2007, 07:34 AM   #121
SmoL is on a distinguished road
hi guys, after 9,999,999 attempts i finally got it to work! What worked for me was as soon as those blue lights go off press 5, followed by the rest of the numbers. Took me forver but this eventually worked for me
SmoL is offline   Reply With Quote
Old 08-13-2007, 10:49 PM   #122
mdlesk is an unknown quantity at this point
Quote: Originally Posted by Blacryan View Post
Here's my issue I am having at the moment. Everytime I input the 588998 code, it just pops up a menu that says English or a bunch of other languages, no "--- - - - -". How do I pull up this menu? I even did a reset on the monitor and I am still not getting this.
I am too having an issue with this. I tried powering it by the control panel as well as the remote, but when I enter the 588998 code I just get the menu selection, in which I actually can't change anyways. I then even tried pressing the menu button, both immediately and after the lights go out, but to no avail. I really don't want to have to solder it. My previous lilliput worked fine, but this new one I received today seems to be giving me some trouble. The model number is 629GL-70NP/C/T
Any ideas?
mdlesk is offline   Reply With Quote
Old 08-23-2007, 05:52 PM   #123
kvp35 is an unknown quantity at this point
worked thanks a lot son
kvp35 is offline   Reply With Quote
Old 08-24-2007, 10:39 AM   #124
easyc is on a distinguished road
Hello everyone. I posted a guide to programming your 629.
http://www.mp3car.com/vbulletin/lcd-...our-629-a.html
Might want to check it out.
easyc is offline   Reply With Quote
Old 08-25-2007, 04:59 PM   #125
jg9
jg9 is an unknown quantity at this point
Thumbs up
Quote: Originally Posted by Nucci View Post
Well, I'm another one. Worked on it for over an hours with no luck. Then tried the remove the battery from the remote trick. On the third try, I was in luck. Here's the link. Specifically, I followed Post #6:
-remove power
-remove battery from remote
-insert battery
-connect power
-press power button
-enter code (normal speed, i tried 2 times slow, didn't work. Third time normal speed, worked like a charm)
http://www.mp3car.com/vbulletin/lcd-display/92097-auto-eby701-lilliput.html
For me (Liliput 7'' 629GL-70NP/CT Transflective) It works exactly like Nucci said. Only on the Third time normal speed, worked.
I get Auto Power On with: 129 0 2 1 0. Default factory configuration was: 129 0 0 1 0.
jg9 is offline   Reply With Quote
Old 08-26-2007, 05:45 PM   #126
frangolfgt's Avatar
frangolfgt is an unknown quantity at this point
On my 619 i have to type 588998 on the remote and then use the controls on the screen to scroll to the part i want to change. the left and right arrows on the right of the screen move up and down and the menu button changes to the next menu. The volume buttons change the selected option. there is a powermode option which I changed from 0 to 1 and it now works.
Here is the full button press sequence:
(on remote)
588998
(on screen conrols)
Menu,Right,Right,Right,Right,Right,Volume up,Menu,Menu.
I didnt get the ----- as some people have and dont have to type in another code, (my first screen is a selection of languages). Hope this helps someone.
Skins:
/showthread.php?t=83814 (R.I.P.)
/104373-golf-skin.html (R.I.P.)
/106214-metal-spin-release.html(RIP)
using own vw gypsy clone
On 2nd PC: 1st one died.
frangolfgt is offline   Reply With Quote
Old 10-19-2007, 09:19 PM   #127
cpufix is on a distinguished road
(on remote)
588998
(on screen conrols)
Yes I have a 619GL - 70NP/C/T
Following the above instructions works fine.
cpufix is offline   Reply With Quote
Old 10-26-2007, 08:32 PM   #128
arturusfury's Avatar
arturusfury is an unknown quantity at this point
I have a 889GL 8" Touchscreen and I had a bit of trouble getting it changed to auto turn on but thanks to diosagain I finally got it. Below are a couple of pictures for the screen showing where to change the power setting if anyone needs it.
I used the remote and entered "588998" and then hit the menu button ON THE SCREEN (not the remote) - once I did that this menu appeared:
Move down to Power Mode and change it from 0 to 2 as instructed by diosagain
should look like that before hitting that power button the last time and then your set. thanks to everyone for the help
[########::] - Planning
[#########:] - Hardware
[######::::] - Software
[######::::] - Fabrication
My Worklog
arturusfury is offline   Reply With Quote
Old 10-31-2007, 08:59 PM   #129
mrpee1881 is an unknown quantity at this point
Touche!! - This worked for me and my transflective purchased from mp3car.com in May '07. I too worked on this for many hours before realizing one thing which I will point out in Nucci's documented sequence.
[Here is a little more detail for anyone who already has the lilliput installed and wired to battery (Carnetix).
-remove power (Turn car off)
-remove battery from remote (Not sure if I had to do this but I did)
-insert battery (Back in the remote)
-connect power (Turn car back on - doesn't have to be w/ ignition running, but the last click before car starts)
-press power button (On the Lilliput Monitor - NOT THE REMOTE)
-enter code using remote (Normal speed, Slow did not work for me also)
- Hit 5 to save
Tested "Auto On" by turning the car off then back on and walah my 5 months of using the remote to turn on my screen everytime I got back in the car was OVER.
mrpee1881 is offline   Reply With Quote
Old 11-20-2007, 08:18 AM   #130
digeratix's Avatar
digeratix is an unknown quantity at this point
I too have the Liliput 7'' 629GL-70NP/CT Transflective and can confirm that nothing worked for me untill I used this code 129 0 2 1 0
digeratix is offline   Reply With Quote
Old 12-09-2007, 04:12 AM   #131
jurassic262's Avatar
jurassic262 is on a distinguished road
well after 20 mins of trying a few things i fianlly got it to work on my ebay double din lilliput. so thanks frangolfgt your easy instructions worked for me
jurassic262 is offline   Reply With Quote
Old 01-20-2008, 09:42 AM   #132
lastlittlelife is an unknown quantity at this point
I have the newer 7" model, the 629, and setting the unit to Auto Power-On was even easier. After pressing the initial code to get into the settings menu, I was brought to an screen. From there, I pressed the controller's "Menu" key several times until I was brought to another screen with a "Power on State" field that I could change to auto-on.
lastlittlelife is offline   Reply With Quote
Old 02-15-2008, 05:27 PM   #133
IceX is an unknown quantity at this point
Same with me > I have also got the new 629 ... I had struggled at first to get into the menu but realized I had to have my PC turned on
I had to set my power state to 2 and had to ensure the auto switch to default was set to PC.
Once I removed power and plugged in again all was working and monitor automatically powered up! Thanks guys!
Now I can through away the remote ... LOL
IceX is offline   Reply With Quote
Old 08-07-2008, 05:24 PM   #134
guido126 is an unknown quantity at this point
Aaaaarrghhh!!! this mod is driving me crazy.
I have two 10pin din 619GL 70NP/C/T screens. bought them seperately 2nd hand though. The first screen already had the softmod enabled.
Cant get the other screen to work, I tried for over two hours and I read every post on the ** internet. Any help VERY appreciated!
guido126 is offline   Reply With Quote
Old 08-14-2008, 05:42 PM   #135
scottgore is an unknown quantity at this point
has anyone done this on a eby701 2008 model lilliput?
all i get when i enter the code slowly is a Language menu?.
HELP!!!
scottgore is offline   Reply With Quote
A different way to Auto – Power – On your lilliput intense LCD/Display 32 05-05-2005 11:49 AM
HELP! lilliput wont power up fenderbender LCD/Display 2 03-02-2005 04:35 AM
DC-DC Car Power for Mac Mini MikeH MacCar 53 02-19-2005 01:13 PM
Power for the lilliput zmann LCD/Display 2 12-04-2004 01:57 PM
ATX auto power on jumpoint General Hardware Discussion 5 01-25-2000 03:56 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
