05-06-2005, 12:17 PM
#1
MySQL Error
Vehicle: 2003/Acura/RSX
ok to put cardboard behind my lilli board?
I put my lilli in a custom case, however the case is too deep and i need to put something behind the board to prop it up. Is cardboard ok? Its vented and the case has plenty of room for air flow.
05-06-2005, 01:00 PM
#2
Banned
Vehicle: 1995 Suzuki GSX-R 750 / 2006 Honda Accord / 2002 Saturn S / 1997 Ford Crown Vic
to be safe i would try to fit the stock lilli piece on it trim it up and stuff its way better that way
05-06-2005, 01:08 PM
#3
MySQL Error
well thats hte prob.. i bought my lilli used and without any brackets or casing. I installed it in my old TFT screen case which works well cause it matches my interior better.
05-06-2005, 02:09 PM
#4
Vehicle: 1993 Eagle Summit
I'd use peices of stiff foam, myself.
05-06-2005, 02:12 PM
#5
Vehicle: 1996 Mercury Sable
But doesn't foam melt?
05-06-2005, 02:15 PM
#6
Vehicle: 1999/Honda/Accord
the only thing you have to be careful of is HEAT. The main board of the Lilli has an element (rectangular in shape) that gets VERY hot.
Is it enough to burn your finger? OH YEAH, as I've found out.
Is it enought to set paper on fire (imagine using the screen for a few hours and the heat building up) or melt foam? Maybe... it would be best to go with a piece of plastic (you should be able to pick up some thin plastic from any hobby supply store)
Epia MII 10000 512MB RAM - 60 GB 2.5" Hard Drive -Opus 90 - Lilliput 7" Touchscreen - Panasonic 8123 Slotload DVD burner - PCMCIA USB2.0 Card - Rikaline 6010 GPS - PS2 Micro Keyboard
05-06-2005, 02:20 PM
#7
Vehicle: 2004 Nissan Murano
I use a piece of hard plastic (similar in size and material to the original case) to mount the board in, then I have a piece of foam that pushes against the back of it to keep it flush.
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
05-06-2005, 02:29 PM
#8
MySQL Error
Vehicle: 2002 Dodge Ram 1500 Quad Cab
you got burned by high voltage, not heat from the transformer, I have 2 lilliputs and that transformer doesnt get hot.
05-06-2005, 04:30 PM
#9
Banned
why not just buy a new lilliput housing mp3car store shud have it or www.digitalww.com
05-09-2005, 07:53 AM
#10
Vehicle: 1997 Chevy Pick-up
I've use cardboard, and it works just fine
1992 z71 Chevy
05-09-2005, 08:31 AM
#11
MySQL Error
This case fits better than the lilli case would. I'll have to take a pic but basically all i did was epoxy the case to the back of the bezel. Its like its from the factory.
| Thread Tools |
| Display Modes |
Linear Mode
