Partial CLE266 S3G 800x480 success
EDIT: Insert generic *Make sure you back up your registry beforehand* disclamer here!
Sorry if this is a repeat of old past information. I did a search and couldn't find anything similar. Having just started my carputer project, I'm new to most of this, but I have had some success trying to get to the native 800x480 resolution for my new 7" Xenarc. I've gotten the xenarc to recognize that there is a 800x480@60Hz signal being outputted from windows by screwing around in the registry. Specifcally, in
HKey_Current_config\System\CurrentControlSet\Contr ol\VIDEO\
There were three entries in that directory, and a few more a bit deeper. Looking around, I saw one that matched my current resolution settings. Simply changing the keys from my current resolution to 800x480@60Hz (decimal obviously), and then rebooting without touching any other setting got me there.
The problem is, is that although the screen looks MUCH sharper than 800x600, it still is not correct and it is streched vertically by a hundred pixels or so such that my task bar is "below" the bottom edge of my screen. To fix this, I've just stretched the windows task bar up till I could finally see it and then let each program resize to that. Over all, it looks pritty nice.
Anyways, thought I would share and hope someone else is able to repeat what I did or better get it working right.
Aux
PCChips M789 v3 w/ Samuel 2000+ S3Vid Lan AC97, 40 GB 7200PRM, 512 DDR266, Xenarc 700YV, PAC AAI-GM9 Headunit Adapter, Sirius Sportster, touchpad mouse input.
