Old 05-12-2005, 08:47 AM   #1
patz's Avatar
prob with sharp of dash and dww-700m
i got prob with dww-700m, because of the sharp of my dash
check the picture
black is the best position (for me)
green is default position (after opening)
but when I open it, screen motor stop moving (because of dash).. but will stay here (red)
(so I use button for move screen to black position)
but when I close screen and open it back, it goes at red position
so, I think the screen does not resume last position when it's stopped during opening ?!
I don't think motor will work for a long time.. (open, jammed because of dash, close, [...] every day)
somebody get this prob too ?
idea how to get screen go to black position when opening ?
sorry for bad english
patz is offline   Reply With Quote
Old 05-12-2005, 09:10 AM   #2
Of Ice and Men
LagunaICE's Avatar
there will be a contact switch on the side rails inside the unit defining in which position motor should stop ejecting screen (i.e. green position on you picture). chances are you can adjust the position by relocating that switch somehow.
LagunaICE is offline   Reply With Quote
Old 05-12-2005, 10:05 AM   #3
takissd's Avatar
hot exactly the same problem as patz. i am just leaving it to see what i am gonna do, though i dont think there will be any problems
-VIA EPIA M10000/512MB/40GB HD
-DWW motorized 7'
-BU 303 GPS w/iGuidance/ CF
-Opus90w
-Belkin Bluetooth
-Pioneer HU
[||||||||||] 95% done
takissd is offline   Reply With Quote
Old 05-12-2005, 02:35 PM   #4
HoSS's Avatar
No, it works with an encoder counting the motor rotations.
Beleive me, i understand mine well after the hours i put in to get it working.
HoSS is offline   Reply With Quote
Old 05-12-2005, 02:55 PM   #5
patz's Avatar
do you have a workaround..
each time I eject my screen.. i think it's the last time it will be ejected
Old 08-17-2005, 05:07 PM   #6
John_Duh's Avatar
mine is very irratic about it... sometimes it will hit the dash, and sometimes it will just stop in the last position.
Does this thing work with some sort of volatile memory ? (thinking of this since i don't leave it powered when the computer is down)
'02 Toyota Celica TS
Carputer progress : [####------]
Currently working on : finding spare time
Parts : pico-ITX, 160Gb SATA, 1.0Gb Ram
Parts needed: USB wifi dongle, USB BT dongle, external storage
John_Duh is offline   Reply With Quote
Old 08-22-2005, 10:38 AM   #7
John_Duh's Avatar
*bump*
Anybody got some input on this, i wouldn't want to fry my screen-motor
Old 08-22-2005, 11:10 AM   #8
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
I find that the screen returns to the exact same spot as when it was retracted. Does your go to a different position.
Are you guys keeping the power wires powered, and just switching the accessory wire to get the unit in and out, or are you removing power completely from the unit when you turn the car off?
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 08-22-2005, 11:44 AM   #9
SAScooby's Avatar
tagging along to learn about this as I think this might be an issue for my next install
Nano ITX / 512 MB / 60 GB / Panasonic slot load / M1-ATX / Bu303 / Sound blaster 24 / PPi amps / rockford sub
FS = MTSVO motorised in dash screen pm me for details
SAScooby is offline   Reply With Quote
Old 08-22-2005, 12:54 PM   #10
John_Duh's Avatar
for the moment i've got it hooked up to the PSU, i.e. not constantly powered. (i'm going to resolder that over weekend)
Normally, when i open my screen it either hits the dash or stops one position further than my last opening position. I would say it's about 25-75% split between what it chooses, but so far i haven't been able to figure out a logic behind it.
Old 08-22-2005, 12:59 PM   #11
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
I have a feeling it may be due to the loss of power.
If you can test it with constant power connected, and just switch the accessory, and let us know how that works.
You might want to slide the unit out, open the unit, set it where you want it, and then remount the unit in the DIN opening.
Mine opens to the same location every time (well, when I tested it at least)
Michael
Old 08-23-2005, 05:59 AM   #12
John_Duh's Avatar
mhhh ... Guess this weekend will be spent fidling with the screen.
I'll post my findings monday.
Old 08-29-2005, 02:12 AM   #13
John_Duh's Avatar
a lil update.
I've been rewireing my screen over weekend and it now has a constant 12V feed. I opened and closed it a lot and it returned to the same position. So i believe i've found an answer to the problem.
Also if you want to wire your screen like this, make sure you do the light mod on your screen so that your dash doesn't look like a christmas tree when parked.
Old 08-29-2005, 02:59 AM   #14
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
a lil update.
Glad it worked, I thought it would.
And you should definitely do the light mod.
Michael
Old 08-29-2005, 06:03 AM   #15
John_Duh's Avatar
just one thing i'm wondering about. Now that it's constantly powered how much drain will that have on my battery ?
The main reason i didn't wire it like that in the first place is that i didn't want the extra battery drain.
