The MP3car.com Store
Thread Tools Display Modes
Old 05-27-2005, 04:52 PM   #16
Jeep's Avatar
Vehicle: 2003 Jeep Grand Cherokee w.22" rims
My Photos: (0)
Worked fine on my old lilliput, but I only have 6 digits. So I did: 001 1 1 1
Anyone know if it's possible to do on a TM-700TS, http://www.digitalww.com/TM700TS.htm
Jeep is offline   Reply With Quote
Sponsored Links
Old 05-27-2005, 05:48 PM   #17
d_sellers1's Avatar
Vehicle: 2000 Ford Taurus & 2001 Ford Focus ZX3
My Photos: (0)
Is it safe to assume that you scroll through the "-------"s to input the numbers since pressing a number key saves the setting? I am assuming that this will work with my screen. It looks just like the TM-810VGT from DigitalWW except the pedestal is different. Same buttons and connector though.
I can't try this right now because I am in Iraq but I am documenting notes, suggestions, and ideas. I'm up to a 23-page Word document with pics.
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 05-28-2005, 05:25 PM   #18
Zebelkhan's Avatar
Vehicle: 2004 Nissan Murano
My Photos: (12)
How many pins you have in your cable? 9 or 10?
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
Zebelkhan is offline   Reply With Quote
Old 05-30-2005, 07:29 PM   #19
Custommx3's CarPC Specs
Custommx3's Avatar
Vehicle: 2007 Mazdaspeed6
My Photos: (7)
Doesnt work on mine, I have the older version (din style connector)
2007 Mazdaspeed 6
Custommx3 is offline   Reply With Quote
Old 05-31-2005, 01:13 PM   #20
Zebelkhan's Avatar
My Photos: (12)
It works! I don't think anyone has a monitor that is older than mine (2 yrs old with 9 pin connector) It so old even the serial number has rubbed off. I just played with it just as the above posts suggest. Never saw the "-------" line but did see the menu with "factory setting" header. I am not even sure what I did because there was no visual prompt but it now turns on and off automatically!
Sponsored Links
Old 05-31-2005, 01:54 PM   #21
Custommx3's Avatar
My Photos: (7)
I put mine in VGA mode and pressed 588998 on my remote. I get no visual prompts at all. I've even tried pressing 588998 then menu, and I see nothing that says factory mode. This sux
Can someone take a pic of the "Factory menu prompt"?
When you guys press the numbers on your remote, do you get anything visual onscreen such as numbers?
I know the remote works, I can power it off and change inputs.
How fast are you guys pressing in the numbers? I've tried going fast, and even holding the numbers down for a second just to see, and still nothing.
2007 Mazdaspeed 6
Old 05-31-2005, 02:01 PM   #22
Zebelkhan's Avatar
My Photos: (12)
Don't give up. Follow this link, read the post by "digitalww" post # 29. That is what I did. (BTW, factory setting appears as a header in the menu)
http://www.mp3car.com/vbulletin/showthread.php?t=49378
EDIT: It definitely works! Just went out and tried it again. These are the steps I took:
1- Power the PC and the lilliput
2- Enter the code 588998 – Do NOT use your finger nails! Use the tip of your fingers to make sure you push the buttons down all the way. Do it slowly, about one digit every two seconds.
3- A little window will appear on the bottom half of the screen with “___ ____”. The header will say “factory setting”. I was so excited when I saw this! On the “footer” of this window you will see the existing code.
4- Enter the codes that you want (see first post in this thread), making sure they are registered as you enter them.
5- Once done, enter any number to clear the window.
If you coded it to have audio in VGA mode, then do the following step:
6- Push on the Menu button. When Menu window opens you will see the header “factory setting”.
7- Navigate to Misc. setting
8- Set Volume mute to “off”
9- Press on Menu button to register this setting. If you don’t the mute will be turned back on automatically.
10- Navigate to exit and exit the menu
When you cut the power to monitor (turning it off will not do it) it will go back to regular menu.
I have a very old Lilliput with 9 pin din. It it worked for me, it will work for anyone. Just be patient. If it does not work the first time, cut the power to reset it, and try again. Also make sure you push the buttons all the way.
Old 05-31-2005, 03:33 PM   #23
mox
mox's CarPC Specs
mox's Avatar
Vehicle: 2003 Renault Clio Initiale
My Photos: (0)
Try this:
1) Completely disconnect the 12V power cord from your lilliput
2) Reconnect power and turn the lilli on by pressing the power button
3) Now, while in VGA-mode, enter the numbers (588998) directly, i.e. without first pressing any other keys or activating any menus or whatever.
On my lilliput (10-pin mini DIN connector), the numbers can be entered at normal speed. No need to type slowly.
Hope this helps!
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
mox is offline   Reply With Quote
Old 05-31-2005, 05:43 PM   #24
FLATLiNE's Avatar
Vehicle: Ford Escort
My Photos: (0)
The way mox described works for me all the time.
Lilliput 7" TS / VIA EPIA M10000 / 256 MB DDR RAM / 40 GB 2,5" Toshiba HDD / TEAC DVD Slimline / GlobalSat GPS USB
FLATLiNE is offline   Reply With Quote
Old 05-31-2005, 08:29 PM   #25
Custommx3's Avatar
My Photos: (7)
well, tried it about 50x, and still no go, either my lilliput is an odd ball, or my remote isnt working. Oh well.
2007 Mazdaspeed 6
Old 05-31-2005, 08:39 PM   #26
Zebelkhan's Avatar
My Photos: (12)
It is important to completely disconnect the power after each unsuccessful try. Otherwise it will not reset.
Old 06-01-2005, 10:55 AM   #27
Custommx3's Avatar
My Photos: (7)
Tried it unplugging the power each time.... no go
2007 Mazdaspeed 6
Old 06-01-2005, 05:22 PM   #28
TMH
My Photos: (0)
I have been lurking for some time and appreciate all th answers I have found so far. Thank You!
I just tried this with a 7" 10pin model 61980891b0140, I can enter the code and it seems to take but I dont think the screen auto turns off. If I turn the PC off the screen just says no vga input then goes blank but the green light is still on.
Not sure if this means anything but, while the PC is off and the monitors light is green I can hit the menu button and the light goes to red for off. When I power the pc it turns green and displays fine.
Is this normal or should the Light turn red when the pc is shutdown? I would assume the auto on/off is not working.
Thanks for anyhelp!
Todd
TMH is offline   Reply With Quote
Old 06-01-2005, 06:44 PM   #29
mox
mox's CarPC Specs
mox's Avatar
My Photos: (0)
The best way to turn off the monitor is by cutting its power. Forget about the auto standby mode, cause it can still drain your battery. Many of us use the PC's 12V rail to power their screens.
As for the red/green light, once you have made changes to the factory settings, disconnect and reconnect the power to properly "activate" the new settings.
Software: RR, MM/FD
Old 06-01-2005, 07:02 PM   #30
TMH
My Photos: (0)
Thanks for the quick response!
I did the disconnect/reconnect to activate thing but the monitor still stays on when you shut down. (green light still on) unless this is how it is suppose to operate. I have gone back into the factory mode and the code I put in does show at the bottom.
Thanks, Todd
Sponsored Links
vB code is On
Trackbacks are Off
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 113 07-16-2008 05:16 PM
Auto Power On 619 Lilliput - Programing Guide Anointed LCD/Display 132 02-15-2008 04:27 PM
Lilliput problem - Gain settings seem to reset Cheater2k LCD/Display 12 09-29-2004 05:26 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 08:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 04:37 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
