06-01-2005, 09:09 PM
#31
I believe you are supposed to disconnect the power completely which would leave no lights on the screen. (not disconnecting the signal cable)
Derek
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
06-01-2005, 09:34 PM
#32
The power is what I disconnected.
Thanks, Todd
06-02-2005, 06:12 PM
#33
This mod is to Auto Power ON not off...
was it suposed to auto turn off two ??
Ikea Case. Epia M10000.M1-ATX. 512 Mb. 2,5" 80 GB HDD. 7" Lilliput. BU-303 GPS. Sony Joystick.
Status --> Lilliput Installed (not indash yet..)
BraveCar 2.5
06-02-2005, 06:35 PM
#34
Tainted Love
Does the auto switching from VGA to AV inputs work too?
06-03-2005, 06:52 AM
#35
And I take it that for the 'audio + VGA' mode to work, you have to plug in that USB type A/V lead as well??..
06-03-2005, 07:31 AM
#36
Quote: Originally Posted by Zebelkhan
It is important to completely disconnect the power after each unsuccessful try. Otherwise it will not reset.
Read all info, tested in my old Lilli, but don't appears the screen to digit the code....tested in all mode posted....
Work in old Lilli this function? (1 year and six months)
Mauri
06-03-2005, 11:55 AM
#37
After I coded the lilliput the thing would power up but then turn off a second later... It was frustrating because I had to use the remote to turn it back on (my screen is custom installed with no buttons visible). Then I rememberd that I had a tape put on the "on" button to keep it pressed in at all times. Removed the tape and it now works... Thought there maybe other retards out there with the same problem.
Compaq Evo D510 e-PC - P4 2.0 - 512M RAM - 120G 3.5 HD - 7" Xenarc 700TSV - DSATX fitted nicely inside the PC case
06-03-2005, 03:21 PM
#38
I tried a hundred times, really won't work for me
Peugeot 206 1.4 HDi
Intel Mini-ITX Mainboard
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
Sb Live 5.1 w/ KXProject Drivers
M2-ATX
8" Lilliput TS LCD
100% installed and working :D
06-03-2005, 03:45 PM
#39
Same here.. and my lilli has NO serial number on it either.
2007 Mazdaspeed 6
06-03-2005, 05:10 PM
#40
MySQL Error
I only try 99 times and still didn't work. I give up.
When I pull the thing out to adjust the lame 9 pin DIN plug, I will do the RC method instead.
06-03-2005, 05:44 PM
#41
Admittedly, I still use the good ol' RC method myself
I've only used the 588998 hack to enable VGA audio.
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
06-03-2005, 07:36 PM
#42
mine is a 8" panel, I haven't seen a rc mod for my panel and I'm not willing to mod without a precise guide and a LOT of positive feedbacks on the mod itself :P
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
06-04-2005, 08:36 AM
#43
The Vauxhall Vectra Project
Anointed - a big thanks to you for this... so how did you come by this info and are there any other Lilliput screens out there that other hacks... like the new in dash ones...
Terran
06-06-2005, 11:00 AM
#44
Something I found out the hard way...... Mine wouldn't bring up the factory code window unless I punched in the code "588998" whilst the "VGAMODE" was shown on the OSD (on screen display). Any other time it won't accept it. I didn't enter it slowly either, I have to enter it before the "VGAMODE" goes away.
Just my 2 cents!
Bj
BjBlaster! Car MP3 & Carputer!
bjblaster.com
"The solution to one problem is only the begining of another"
06-06-2005, 11:07 AM
#45
will try, thanks
Peugeot 206 1.4 HDi
Celeron 1.2ghz
256mb DDR-2 533
80gig 3.5" SATA HDD
M2-ATX
8" Lilliput TS LCD
| Thread Tools |
| Display Modes |
Linear Mode
