Old 10-07-2005, 12:18 PM   #61
Bob T1 is on a distinguished road
How the hell do you discover this kind of thing?
Bob T1 is offline   Reply With Quote
Old 10-22-2005, 03:40 AM   #62
DK888 is on a distinguished road
I'll test this coding on the new monitor I got. But on the last one, surprisingly it has auto on from factory. Unless....it was refurbished. err..
My 2000 Accord Project
DK888 is offline   Reply With Quote
Old 11-14-2005, 10:02 AM   #63
barb3tta is on a distinguished road
Quote: Originally Posted by Zebelkhan
It definitely works! Just went out and tried it again. These are the steps I took:
1- Power the PC and the lilliput
2- Enter the code 588998 – Do NOT use your finger nails! Use the tip of your fingers to make sure you push the buttons down all the way. Do it slowly, about one digit every two seconds.
3- A little window will appear on the bottom half of the screen with “___ ____”. The header will say “factory setting”. I was so excited when I saw this! On the “footer” of this window you will see the existing code.
4- Enter the codes that you want (see first post in this thread), making sure they are registered as you enter them.
5- Once done, enter any number to clear the window.
I have a very old Lilliput with 9 pin din. It it worked for me, it will work for anyone. Just be patient. If it does not work the first time, cut the power to reset it, and try again. Also make sure you push the buttons all the way.
Hi!
I also have the 9pin-din lilliput. It's a newision NW619VT, a re-branded lilliput 619GL-70N/P/T.
I bought it on march 2004. I can't access to the factory settings.
I wrote an email to newision germany (the one who sold me the lilli) for have some infos about entering the factory menu.. Still waiting
Well, I think I'll go with the coyote mod!
bye
barb3tta is offline   Reply With Quote
Old 11-15-2005, 09:34 AM   #64
cjjacquez is on a distinguished road
Question Liliput codes brightness
Guys I also have my lilly 629 (new model) working with the auto power on codes
question:
The brightness is set to max so everytime I need to down using the screen button to reduced the light intensity... is there a way to set this intensity with a code as default??
Also I noted the only butto iluminated is the power on.. and if i push the others (menu, or volume) they light but just for a few seconds.. is this normal??
Is there a way to have them all turned on always?
please advice
cjjacquez is offline   Reply With Quote
Old 11-15-2005, 02:09 PM   #65
Hi!
I got response by newision
Quote:
The way to access factory setting are totally different between different monitors. We make this to protect our exclusive authorization technic. So sorry about this convenience.
If you really like this function as you mentioned in your letter. I suggest you buy our new NW619VT. We can make the special auto power on function for you. And I think the price for this special NW619VT will be much more competitive too. Pls consider.
Why I have to buy another lilli when I could do a RC mod?
Anointed, can you please tell me how you find the code to access to factory settings? TIA
bye!
Old 11-19-2005, 11:46 AM   #66
MobiTekLink's Avatar
MobiTekLink is on a distinguished road
This thing doesnt seem to be working with the 629
08 Lincoln Navigator www.mobiteklink.com
MobiTekLink is offline   Reply With Quote
Old 11-27-2005, 04:15 AM   #67
bigdongers is on a distinguished road
does anyone know if these codes work with the composite Lilliputs with built-in TV tuner? like the 718GL?
bigdongers is offline   Reply With Quote
Old 11-28-2005, 10:59 AM   #68
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
The Lilliput model number only indicate what it look like outside. What mater is inside. Lilliput going thru many revision with the internal to make it better.
Mine doesn't work with the mod, but many other people got it works.
You can always do RC mod. Or if you like me, jam the power button (make it stuck down) and you have auto on. Easiest mod.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 11-28-2005, 11:00 AM   #69
MySQL Error
MatrixPC's Avatar
You try it out and let us know.
More likely, none of us has that screen to try.
Old 07-20-2006, 09:35 PM   #70
wasyed is on a distinguished road
2006 lilliput 7-inchers
in case anyone is wondering, for the lilliput EBY701-NP the fifth blank is different for the lilliputs model # EBY701-NP... instead the 5th number you have to choose 2 in order to have auto power on. The code is mixed for these new lilliput models so instead you need :
0: Start with same mode as the mode before power is disconnected.
1: Start with Power-off mode when power is connected.
2: Start with Auto Power-on and standby mode when power is connected.
Car: Nissan Maxima 1997 5-SPD
Current carputer status: 92%
my carputer worklog: click here
wasyed is offline   Reply With Quote
Old 11-13-2006, 02:34 AM   #71
NiSlo's Avatar
NiSlo is an unknown quantity at this point
Second that. Just did it on my 701 that arrived today. I had no problems doing it.
1. Entered 588998. OSD came up with --- - - -
2. Entered 097 0 2 0 (English, Chinese and Japanese as languages, English as default, Auto Power-On, sound in VGA, without tv input)
3. Once all numbers were entered, I pressed 5 (any button works) to close the OSD (on screen display)
4. Tested it by cutting the power, reconnecting it and voila! Turns on automatically when the power is connected...
Sweet!
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 11-14-2006, 07:59 PM   #72
RooDBwoY's Avatar
RooDBwoY is an unknown quantity at this point
works a treat here mate many MANY thanks.
not sure what the model number of mine is, because it's not on it, but it's a 7" widescreen lilliput
RooDBwoY is offline   Reply With Quote
Old 01-02-2007, 09:32 AM   #73
Perrosky's Avatar
Perrosky is on a distinguished road
question:
please advice
I got the 629 I get it from mp3car.com I been try to get it on auto power on but I can't get not even to the factory set up and I been trying in every way I push the buttons slowly and all that but the factory setup don't come out.
Auto Power On New Lilliput - Programming Guide
You could try the following reset:
1.In VGA mode with your PC turned on (Recommended) , SLOWLY Input "588998" to come into the "factory setup" with the remote control unit.
is there another code for this particular model??
thanks!
One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
Perrosky is offline   Reply With Quote
Old 01-02-2007, 03:08 PM   #74
Ste_nova is on a distinguished road
i can get into factory setup on mine... but i get menus not a line of numbers???
2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch, bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
Ste_nova is offline   Reply With Quote
Old 01-02-2007, 05:47 PM   #75
tmproff is an unknown quantity at this point
Mine was the same way. I got a menu, but no place to enter the codes. I used my remote to type in the code needed to get into the system mode, THEN I pushed the menu button on the screen itself to get to a new more sophisticated list of options in a menu. One of the options in that menu was for the auto on. Good luck!
tmproff is offline   Reply With Quote
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 115 10-26-2009 05:33 PM
Auto Power On 619 Lilliput - Programing Guide Anointed LCD/Display 141 07-02-2009 05:21 PM
Lilliput problem - Gain settings seem to reset Cheater2k LCD/Display 12 09-29-2004 06:26 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 09:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
