01-03-2007, 07:08 AM
#76
Quote: Originally Posted by tmproff
Mine was the same way. I got a menu, but no place to enter the codes. I used my remote to type in the code needed to get into the system mode, THEN I pushed the menu button on the screen itself to get to a new more sophisticated list of options in a menu. One of the options in that menu was for the auto on. Good luck!
are u talking about the lilliput 629? if u do can u please tell me the steps u exactly in the way u did it, to see if I got the same luck?
thanks
One of the best way to learn is making mistakes, But much better when you learn from someone else mistakes
01-04-2007, 11:48 AM
#77
I found the way to doit and everything work good, but when I disconect the power and conect it again the monitor don't power on, still on stand by.
can that be because I don't got the usb cable connected to the pc.?
Its working... for somereason powered by the opus psu don't turn on but when i plug it with the cigarrete light adapter it turn on when recieve the signal.
Reason: now it's working
01-12-2007, 05:17 PM
#78
I am hoping someone can help me out i have this screen http://cgi.ebay.com/ebaymotors/ws/eB...3450279&rd=1,1.
however when I enter the code i get a menu to choose the factory languages but that is it any help yould be great and I can post pics if that would help
01-18-2007, 05:07 PM
#79
I solved this a while back. When you get to the menu where it lets you switch languages, PUSH THE MENU BUTTON ON THE MONITOR ITSELF. It will give you a new menu with all sorts of options.
01-18-2007, 05:10 PM
#80
thanks you I will look into this when I put my psu back in car tomorrow
Thanks,
Yonu
01-22-2007, 05:55 PM
#81
tmproff you rule, this was bothering me... the remote wouldnt respond once in the menu..
Anyone with a screen that goes to language selection or another menu when entering 588998 you need to nav with the buttons on the screen..
thanks again tmproff, you saved my life..
01-24-2007, 05:40 PM
#82
Quote: Originally Posted by Cris
Does the auto switching from VGA to AV inputs work too?
Has anyone done this yet. I am thinking of getting a rear-view camera and would like the lilliput 629 to auto-switch
02-17-2007, 03:11 PM
#83
wait I'm confused. I have the power hooked up to my accessory line in the car so if i shut the car off it cuts the power. You guys say that cutting the power resets the monitor. So is there a way for me to have it so that when the car is turned on (power is turned on to the monitor) that the monitor automatically turns on and displays my computer?
02-17-2007, 04:44 PM
#84
it does? hmm mine doesnt reset the monitor settings at all. I thought there was a setting in the monitor to retain the setting or something. I didnt have a problem at all with either of my lilliputs I had so not sure. My car ccuts out the power as well and when i start the car back up, the settings that I had remain in there still.
Car: Nissan Maxima 1997 5-SPD
Current carputer status: 92%
my carputer worklog: click here
03-22-2007, 06:33 PM
#86
I am so ****ed off. I have spent the last 3 hours trying every which way to make this work on my 629GL-70NP/C/T.
No matter what method I used, and i've used every one on this and rtthe related thread, I get absolutely no sign of Factory Mode/Settings,nothing.
Anyone tried anything recently that might help????
Colin
03-29-2007, 06:24 PM
#87
VENDOR - Centrafuse
Colin
Second that. I bought a 629 about 9 months back and it works fine. But I just received a new one, and I cannot get into the factory settings and cannot set the auto power on feature. Very annoying that they would change this.
Please help !
03-29-2007, 07:59 PM
#88
VENDOR - Centrafuse
Figured it out. As I saw elsewhere in other posts, I had to remove the battery from the remote and the power completely from the LCD. Then power both back up, and here is the mistake I was making, you have to turn the power on using the screen button (not from the remote!) before you type in the "588998". Works like a charm now. Also, I had to press the buttons fairly normal speed. I saw in other posts that you had to enter them slowly, but this didnt work for me.
Hope that tidbit helps, I saw in no other posts about having to turn the power on from the screen button...
05-10-2007, 01:22 PM
#89
Does anyone know if there is a way to disable the "No input signal detected" message on EBY-701?
05-17-2007, 01:13 PM
#90
Quote: Originally Posted by NiSlo
Second that. Just did it on my 701 that arrived today. I had no problems doing it.
1. Entered 588998. OSD came up with --- - - -
2. Entered 097 0 2 0 (English, Chinese and Japanese as languages, English as default, Auto Power-On, sound in VGA, without tv input)
3. Once all numbers were entered, I pressed 5 (any button works) to close the OSD (on screen display)
4. Tested it by cutting the power, reconnecting it and voila! Turns on automatically when the power is connected...
Sweet!
I have a EBY701 but this tweak is not working for me.
i entered 588998 and i get a ****ty menu instead of "-------"
am i spose to see this? this menu reacts to nothing. i proceed to keying in the codes 1270200 (i dont want to enable speaker)
as its no surprise, it dosnt work, so i tried 1270210 , no banana either.
problem is i cant see a damn thing im keying in.. so i couldnt know if i hit the button or not... help help!!
| Thread Tools |
| Display Modes |
Linear Mode
