Old 12-03-2008, 09:12 PM   #121
daryldc1991 is an unknown quantity at this point
Lilliput 8" Widescreen (16:9) VGA Touchscreen
Can someone help me with my monitor. A little while back I was trying to do the auto on mod using the codes. I think I may have entered the wrong code because my monitor now will only display in 640x480 . Is think this is because I entered the wrong code. I there a code that will revert my monitor back to the factory settings?
thanks in advance for any help
daryldc1991 is offline   Reply With Quote
Old 03-24-2009, 01:12 AM   #122
sniperscout is an unknown quantity at this point
i have an eby-701...is there any way in the advanced menu to make it so the side buttons stay illuminated instead of turning off after 10 secs
2004 NHBP EM2
K24 Frankenstein Swap
212hp/180TQ
sniperscout is offline   Reply With Quote
Old 04-14-2009, 05:32 AM   #123
monty9991 is an unknown quantity at this point
Quote: Originally Posted by Spawn12336 View Post
I just recently got the same monitor. Like most of the previous posts said, once you have entered the 588998 on the remote, you use the hard buttons on the side of the monitor to navigate the menu. You select you language, then press menu to move on to the other options. Worked perfectly for me.
worked for me on EBY 701.. thanks
monty9991 is offline   Reply With Quote
Old 04-15-2009, 05:24 AM   #124
masdan is an unknown quantity at this point
help me
Hi. I'm italian.
i've read some of this thread.
i've write the code and i switch on the TV option.
Now i don't see nothing on my lilliput and i don't know what to do to come back.
Sorry for my English.
masdan is offline   Reply With Quote
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 115 10-26-2009 05:33 PM
Auto Power On 619 Lilliput - Programing Guide Anointed LCD/Display 141 07-02-2009 05:21 PM
Lilliput problem - Gain settings seem to reset Cheater2k LCD/Display 12 09-29-2004 06:26 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 09:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
