Old 05-19-2005, 10:02 AM   #1
mort is on a distinguished road
Lilliput Display is Terrible - Are there Display Drivers for XP?
I just installed my new 8" Lilliput touch screen, and since I also got the small cdROM, I downloaded the TS software from the sight listed here (4.0 version), and my TS works fine.
HOWEVER, the display of the Lilliput is awefull - washed out white tint that will not change with the monitor settings. I still have graphics on the screen -(not just a blank white like mentioned on other threads), but it is all "washed" out in color. Is the any MONITOR DRIVER SOFTWARE (not TS) that I am missing that is specific monitor driver software for XP (again, my toch screen drivers work fine)? I had a cheap Hami 8" monitor which has a terrific display. This new Lilliput is "not" good, washed out regardless of changin settings on the monitor and XP. Is there any specific Lilliput monitor software avaialble since XP is only using "default drivers" for the monitor? Thanks!
mort is offline   Reply With Quote
Old 05-19-2005, 12:17 PM   #2
dodgetimes2's Avatar
dodgetimes2 is on a distinguished road
If the monitor is good it will work display without any special drivers. The only software you need is the touchscreen driver. Sounds like you might have a loose cable somewhere.
1.6GHz HP e-PC, 768MB RAM, 120GB WD HDD, Slim DVD-ROM, Onboard sound & video, 7" Lilliput, USB GPS Mouse, Audiovox FM Modulator, Vector 400 Watt Power Inverter, Windows XP Pro SP2, iGuidance 2, 15" Samsung LCD for the rear *Carputer not installed*
dodgetimes2 is offline   Reply With Quote
Old 05-19-2005, 05:56 PM   #3
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
No, there are no monitor drivers.
And really, that's what happens when you buy a display that is a refurbished pachinko machine display....
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 05-19-2005, 06:20 PM   #4
-zip-'s Avatar
-zip- is on a distinguished road
What happens when you try to calibrate it?
Could be a loose wire, do the new ones still have the barrel plug thing, if so it could be a bad connection there as well.
Mine had the same problem. Had to ship it back to lilli U.S.A and get a new one. Mine would not display the color red.
Carputer
Installed Since April 2, 2005
Intel D201GLY|Fusion Brain|Audigy2 NX||ODBPros ODBII|Engenius362ext |Motorized lilli|GPS Rikaline 6010|Opus 150|Powermate|Ergonomic Touchpad|
Sound Stage
Eclipse CD8455|MTX TA3404+421D|Infinity Comps|ID 12" Sub
-zip- is offline   Reply With Quote
Old 05-20-2005, 04:12 AM   #5
Nic
Nic's Avatar
Nic is on a distinguished road
like everyone said the drivers will not do anything, you need to screw around with the settings on the monitor, make sure all 3 color settings are at around 33 and the brightness/contrast is correct, otherwise you have a dud monitor
Signature: [==||========] 20% complete
Nic is offline   Reply With Quote
Lilliput Drivers for XP Showmehow Newbie 3 07-21-2004 11:18 AM
rotate Lilliput display 180 degrees tjb1231 LCD/Display 5 06-15-2004 12:55 AM
Display area of Lilliput 7in bobbykokinos LCD/Display 4 03-17-2004 09:49 AM
WIERD Display on Lilliput...HELP! Norrin302 LCD/Display 11 03-09-2004 09:48 PM
Small Lilliput display problem Da_Teach LCD/Display 17 03-01-2004 07:23 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
