The MP3car.com Store
Thread Tools Display Modes
Old 05-20-2005, 09:07 AM   #1
Vehicle: BMW 325is
My Photos: (0)
Screen interference - grounding?
I'm getting some annoying interference on my Xenarc in dash. I think it's picking up some interference on the 20' or so run to the trunk. I get lines on the screen that increase in frequency with the engine, leading me to believe that it's not adequately grounded. Is there an easy way to ground the VGA cable? I was thinking about hooking up a wire from the shielding on the VGA cable to ground on both ends - would that help? Should I also be hooking the computer case up to the car's ground? Any ideas? I'm also getting the all-to-familiar alternator whine when no music's on, but that's not as annoying as the screen interference.
Thanks,
Dan
dmurray14 is offline   Reply With Quote
Sponsored Links
Old 05-20-2005, 09:34 AM   #2
Raw Wave
Gobby's CarPC Specs
Vehicle: Pug 306 XSi
My Photos: (0)
I also get this but don't know how to sort it, my noise also effects the speakers and the screen generates noise from the backlight inverter.
Gobby is offline   Reply With Quote
Old 05-20-2005, 09:49 AM   #3
neon_eddy's Avatar
Vehicle: 1999 Audi A4 1.8t
My Photos: (0)
get heavy gauge wire or use lots of smaller guager wire to ground your case, and screen ..
GROUNDING GROUNDING GROUNDING! I also got a aftermarket VGA cable the stock ones have little grounds, and little shielding.
mine is EMI free right now.. but who knows I'll mess something up
Shawn
Check out my web company Minneapolis Web Designer - Himmelberger Design
Minneapolis Computer Repair - Alt Repair - A friends computer repairs place, good for carputer repair too!
neon_eddy is offline   Reply With Quote
Old 05-20-2005, 12:01 PM   #4
Vehicle: BMW 325is
My Photos: (0)
Will do. Case is currently ungrounded. Should I try grounding the VGA cable shielding as well?
Thanks,
Dan
Old 05-20-2005, 12:44 PM   #5
neon_eddy's Avatar
My Photos: (0)
yes.. ground everything and anything until the picture cleans up .. think of electricity like water.. it needs to flow through least resistance. right now it's flowing easier through your LCD than to the normal ground..
and try connecting and disconnecting other things to see where the noise os coming from..
mine happened to be the case .. and it needs to be a solid ground.. I had to screw it in tight before it cleaned up..
Shawn
Old 05-20-2005, 12:46 PM   #6
kmcniece's Avatar
Vehicle: Scion xB
My Photos: (0)
Best description of grounding problems ever........
EPIA M10000, 512 Ram, Opus 90, GPS, XM, 7" Xenarc, Pioneer HU
Status:
Installed & Working....
Custom enclosures
Newbie Guide
kmcniece is offline   Reply With Quote
Old 05-25-2005, 11:21 PM   #7
My Photos: (0)
I have my Lilliput screen getting power off the power supply, I have 12v and the ground ran from the power supply to the lcd. Should I just cut the ground on the lcd and ground it to the chassis of the car?
jeeve76 is offline   Reply With Quote
Old 05-26-2005, 07:56 AM   #8
My Photos: (0)
read my post in the Xenarc FAQ
live2themaxuk is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Anyone care to help me with a mystery screen? Rover_Eli LCD/Display 34 03-27-2007 07:34 PM
I can't come out of full screen with movies, but can with text clean customs FrodoPlayer 4 01-29-2005 06:35 PM
Inverter making the screen go off and on, and cut it. PLEASE HELP clean customs Power Supplies 23 01-20-2005 06:41 PM
Has anybody ever got lil/Xen screen to clock onto native res? ChrisC LCD/Display 5 04-30-2004 11:25 AM
BMW pre-installed system - TFT ? tsingsu LCD/Display 11 08-05-2002 02:16 AM
Sponsored Links
Ad Management by RedTyger
