Old 05-29-2005, 09:19 AM   #1
the4ork is on a distinguished road
is this screen any good? 10.1"
i just have a few questions,
1. am i going to be happy with the brightness of this unit?
2. does it use a normal PC connector for video?
3. can i run the touchscreen on windows media center ed. easily?
4. is the touchscreen a PITA to set up?
Diagonal Display Size 10.4" (26cm)
Drive Type Active Matrix TFT
Dot Pitch 0.1mm (H) x 0.33mm (V)
Pixel Number 640 x 480 VGA resolution
Input Signal Analog RGB
Pixel Pitch 0.33mm (H) x 0.33mm (V)
Active
Display Area 211.2(H) × 158.4(V) mm
Pixel Configuration RGB Vertical Stripe
Luminance 300 cd/m2 or 500 cd/m2 (typical)*
Contrast Ratio 300:1 (typical)
Display Color 242,144 colors
Viewing Angle 40° from top, 55° from Bottom Right/Left 60°
Response Time Rise: 15ms, Decay: 35ms
Refresh Rate 60Hz
Power Consumption 300 or 500 cd/m2 less than 15W
Operating Temperature 0°C to +50°C
Storage Temperature -25°C to +60°C
Humidity 95% RH, non-condensing
Weight (w/o mounts) 4.5lbs (2.0Kg)
Construction Housing made of ABS and aluminum alloy
Connectors Video: Standard BGA 15-pin connector;
Serial Touch: Standard DSUB 9-pin connector;
Optional 5' cable for touchscreen
the4ork is offline   Reply With Quote
Old 05-29-2005, 09:41 AM   #2
markbuts3 is on a distinguished road
Sounds like the datalux I'm selling....
There are two models, one is 300cd/m2 and one 500cd/m2. Any idea which it is ??
Yes it has a std 15 pin VGA connector with 9 pin serial for touchscreen. I never used mine in the car as I got a Xenarc. The touchscreen was easy to setup on mine...
Quick vid of mine
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 05-29-2005, 04:56 PM   #3
fuctup's Avatar
fuctup is on a distinguished road
how much? if its cheap id get it
fuctup is offline   Reply With Quote
What's a good 7" VGA in-dash touch screen? phatrabbitzz LCD/Display 9 07-17-2004 10:39 PM
Has anybody ever got lil/Xen screen to clock onto native res? ChrisC LCD/Display 5 04-30-2004 12:25 PM
What the....same screen? Good screen? Seabass General Hardware Discussion 4 03-31-2004 12:37 AM
is this a good screen smoke3ngu LCD/Display 1 05-07-2003 01:02 AM
Well, I've bought a screen, but I won't know how good it is for a little while. Skraggy_uk LCD/Display 2 03-30-2003 10:36 AM
