Old 06-01-2005, 09:50 AM   #1
UHF
UHF is on a distinguished road
cant see my lilliput in daylight :(
I've just got my project into my car FINALLY and the 7" lilliput is totally unreadable during the day.
Is there anything I can do to this screen, if not, are the xenarcs much better? I've been sat behind people in traffic and watched movies from the screens in the rear of thier headrests so I find it hard to believe there isnt a VGA screen which will let me read it from 2 foot away.
Preferably i'd like to have it in dash, is the Xenarc 7" in dash up to the job, as its a lot of money to spend to find out its just the same.
UHF is offline   Reply With Quote
Old 06-01-2005, 09:59 AM   #2
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
not a lot of difference between the two......tinting the windows helps.....mounting it in such a way to avoid dirrect sunlight might be an option for you......there are threads discussing modifing these screens with extra ccfl's for extra brightness...but that's not an easy solution......trust me, your not the first to complain.....
turbocad6 is offline   Reply With Quote
Old 06-01-2005, 10:10 AM   #3
MySQL Error
jcdillin's Avatar
jcdillin is on a distinguished road
welcome to the club, here is your t-shirt and your hat
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 06-01-2005, 10:25 AM   #4
Raw Wave
RoyN's Avatar
RoyN is on a distinguished road
Wait tight and look at the links on kcdillin's sig...
RoyN is offline   Reply With Quote
Old 06-01-2005, 10:28 AM   #5
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
No ****! now join the upraded backlight revolution!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 06-01-2005, 10:37 AM   #6
ElKeeed is on a distinguished road
I dont think the problem is that they are too dim but simply that they are too shiny with the touchscreen.
I sprayed some uv coating stuff I found at work on mine and that helps a lot but rubs off with all the touching the screen gets. Its foreign so I'm not exactly sure what it is but I need to find out before it runs out :P
ElKeeed is offline   Reply With Quote
Old 06-01-2005, 10:54 AM   #7
markbuts3 is on a distinguished road
I find my 700IDT to be quite good in the day, I've not tried on a VERY sunny day but it was quite sunny the other day and it was OK...
Old setup
Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
New setup
Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
markbuts3 is offline   Reply With Quote
Old 06-01-2005, 12:18 PM   #8
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
how ur lilli is powered plays a role in its brightness. I tried hooking it up to the PSU and it was HORRIBLE. Having it egged fused and powered directly to the battery makes a huge difference.
Old 06-01-2005, 12:32 PM   #9
MySQL Error
jcdillin's Avatar
which is strange because my egg puts out the same voltage as my PSU, I see no difference between the egg and PSU
must be some are more powerful than others
肚子笑痛了
S60 Install
Old 06-01-2005, 12:52 PM   #10
Terminal flasher
My egg lets just over 13v thru but my psu sits just above 12. But the difference in terms of output is huge
Old 06-01-2005, 02:03 PM   #11
schapman43 is on a distinguished road
You're PSU may not have the amperage available that your egg does.
schapman43 is offline   Reply With Quote
Old 06-01-2005, 02:07 PM   #12
MySQL Error
jcdillin's Avatar
the egg makes it to 2 amps before it starts to complain, my PSU can handle well above that. But my egg only puts out 12.5 volts. The only way I was able to get the backlight to be brighter on my lilliput was to bypass the regulator circuit for the inverter and power it directly. Which the backlight became awesome in brightness, but the inverter blew within a few hours. Not to mention it went up to a 1.8amp total draw for the screen
肚子笑痛了
S60 Install
Old 06-01-2005, 02:09 PM   #13
TheKingPlaza is on a distinguished road
get rid of the touch part.. that will do the thing!
or don't drive by day time. I know.. this really sucks..
TheKingPlaza is offline   Reply With Quote
Old 06-01-2005, 02:09 PM   #14
MySQL Error
sounds typical of lilliput to be honest! Xenarc would never have inconsistancies like that!
(Jerry is the lilliput guy i am the Xenarc guy )
Old 06-01-2005, 02:11 PM   #15
MySQL Error
jcdillin's Avatar
honestly the only thing i've found by removing the touch panel, is you remove some of the glare, it really doesnt make it that much brighter
肚子笑痛了
S60 Install
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 115 10-26-2009 05:33 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 09:41 PM
Lilliput TS - Are they ALL this dim in daylight??!! kenop LCD/Display 12 07-05-2004 12:02 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
