Alright I have a Xenarc 700TSV
For In-Car Computing, PC, Server, GPS, and various VGA Use
4-wire resistive Touch Screen (USB)
Multi-Monitor Touchscreen Support
VGA Input (15 pin D-SUB) x 1 (700TS) or VGA Input x 1 & Video Input x 2 (700TSV)
Audio Input / Built-in Speaker (700TSV)
NTSC / PAL Multi-System (700TSV)
16x9 Aspect Ratio
High Resolution Display - up to 1600 x 1200
Auto detects 800x480 resolution
Upgraded High-Brightness CCFL Backlight
Adjustable backlight level for night-time use
Pixelworks High Performance Video and VGA Processor
High Quality Scaling & Anti-Aliasing
16:9 / 4:3 Scaler settings *New*
Last Input memory (700tSV) *New*
IR Remote Control (700TSV) *New*
Auto power-on upon signal detection
Automatic display adjustment
On Screen Display Control
Metallic Silver or Black Casing
Copper Stand: 360° / Height Adjustment
20-Pin heavy-duty connector
Anti Glare Coating
Supports 11V DC ~ 24V DC
"E" Mark Certified for Automotive use
Compare Features
I have it wired to the OPUS Power supply 12v rail. The problem I am having is the colors on the screen ONLY while playing movies or view pictures I get chunky, blocky what ever you want to call it images and I don't know why.
I have tried powering it with the supplied cig lighter plug and also tried this in the house and got similar results. I get a cleaner image with the OPUS PSU vs the dirty power from the cig lighter but I still get the chucky blocks etheir way in videos or pictures and menus.
My display settings are exact to the faq per xenarcs website
800x480@60 and I tried the 800x480@61 also
This is how it looks on my home computer.
This picture is a little faded from the camera but if you look at the buttons then have the two toned color it looks like its almost 256 colors only.
The funny thing about the screen in the car is that I wired up the just + side of the wire and left the ground unconnected and I thought it was wierd that it power up. My thoughts on this are that it is getting its ground through the vga connector.
I feel like thats not the problem I have since wired the ground wire with no change it color.
When I first but this unit I had one that the touch controller was bad on and it did the same color problem so I don't think this is a wiring issue.
Can someone help me out here I am so it the dark now with this
thanks
