Old 06-08-2005, 08:59 AM   #1
12V line for LCD from Stereo harness
Hey Guys -
Searched but didn't find an answer -
I'm removing my stereo to replace it entirely with a carputer - RCA jacks (from a Metra wire harness connected to the original stereo harness) will plug into laptop outs.
On the harness, there's a 12V line thats not used (along with dimmer and acc) since there won't be a head-unit on there. The wire looks like it's 16 gauge - have any of you guys powered your LCD from this line?
I don't think there'd be any problems, since the stock stereo/other cd units probably draw more current than the LCD, but I just wanted to make sure you guys didn't run into any problems doing this. (I'll still put an ldo in for regulation).
chiefwigms is offline   Reply With Quote
Old 06-08-2005, 09:08 AM   #2
odleon's Avatar
it will be fine.
Mods: Too Many.
Pics Of The Ride:PT Turbo
odleon is offline   Reply With Quote
Old 06-08-2005, 09:24 AM   #3
MySQL Error
jcdillin's Avatar
yup it will work great, I actually power mine from the ACC line so the LCD turns off and on with the car.
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 06-08-2005, 09:56 AM   #4
MySQL Error
MatrixPC's Avatar
It works but becarefull cuz it is not a regulated 12V source.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 06-08-2005, 10:56 AM   #5
nice! thanks
Old 06-08-2005, 11:10 AM   #6
deetap's Avatar
...but is it possible to use this 12v source for both the hu and the lcd, at the same time?
I so want to do this, to limit the amount of wiring needed.
deetap is offline   Reply With Quote
Old 06-08-2005, 11:44 AM   #7
Confusion Master
Enforcer's Avatar
You might have issues with current consumption. ie when you have the volume up and bass going through, screen might flicker.
Enforcer is offline   Reply With Quote
Easiest way to tap a 12V accessory line fluffy2097 Newbie 16 08-08-2004 02:20 AM
12V line, how important? slboytoy Power Supplies 4 05-13-2004 08:25 AM
Possible Solution for Dual Sproggy 12V @ 10A mp3z24 Power Supplies 5 07-10-2003 01:33 PM
PSU 12V issue Shades Power Supplies 2 05-23-2002 03:59 AM
How many Amps on the 12v line? Machs_FueL Power Supplies 2 06-05-2001 09:00 PM
