Hi All I got a Savv LOH-7000 from ebay and knew when i bought it I knew it had no wiring connectors with it. it's a 13 pin DIn type (?) it looks the exact same as the type you use for a boot changer
I purchased it so i couild link it up with my Playstation 2 in my car but figure it out
Heres the wiring connections as it says on the back of the monitor
1 - Audio R (AUX 2)
2 - Audio L (AUX 2)
3 - Audio R (AUX 1)
4 - Audio L (AUX 1)
5 - S. GND
6 - NC ?? What This
7 - ACC ?? Whats that
8 - Batt
9 - REMOCON
10 - VIDEO (AUX 2)
11 - VIDEO (AUX 1)
12 - NC ?? ALSO THIS
13 - P-Ground
SPECS OF THE TFT
Universal 7" Overhead Monitor
High Definition, Low-Reflection TFT LCD
Resolution : 1440 x 234
Screen Size : 152.4 x 91.44mm (16:9 aspect ratio)
Video Input : 1Vp-p, 75 ohms (Composite)
Composite Video Input Signal
PAL/NTSC Selectable
External Dual AV Input
Image Inversion (left to right)
Swivel Mechanism (left to right)
3 Position Large Dome Light
Full Function Remote Control Included
Built-in Infrared Transmitter
Dimension(mm) : 240(W) x 357(H) x 50(D)
I have a a 5 meter Clarion Boot changer with 13 DIN plugs at either end can this be modified so one end can be made in to RCA and power the monitor and also for sound
I've scanned google and manufacturers but no avail
