Old 06-17-2005, 06:39 AM   #16
mox
mox's Avatar
mox is on a distinguished road
Quote: Originally Posted by Marsupial
nice turnaround - using the stock part for custom apps...
there should be a similar hack to xenarc or any other device with an IR eye...
I think any stock 3-pin IR eye will work.
Good find, thanks. Girder is hard to understand without a proper howto.
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
mox is offline   Reply With Quote
Old 06-17-2005, 07:01 AM   #17
mox
mox's Avatar
Quote: Originally Posted by Cheekz185
Does any1 know if there is something like this for the Xenarc 700tsv?
I am sure there is. If you can take a close up picture of the IR eye and its surrounding components, I might be able to help. Any numbers on that IR eye?
Software: RR, MM/FD
Old 06-17-2005, 07:19 AM   #18
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Quote: Originally Posted by antimatter
You don't use the lilliput remote you use any other remote with more buttons that can be programmed to to go things, anything with girder
K thx for the info.. guess its time to hack the ole lilli open again. All i would really want is control over playback functions in RR/winamp and maybe the ability to switch between music and gps mode. I take it these things are acheivable thru girder? If all this pans out i just might forget about replacing my touch screen!
Old 06-17-2005, 07:27 AM   #19
Raw Wave
Gobby is on a distinguished road
Yeah girder should allow you to do what you want, once you understand it all that is!
Gobby is offline   Reply With Quote
Old 06-17-2005, 07:54 AM   #20
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
i really dont understand what the fuss is all about making girder work......i think its a very intuitive very easy to use program
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 06-17-2005, 11:11 AM   #21
mox
mox's Avatar
Almost just as easy as hooking up that IR eye
Software: RR, MM/FD
Old 06-17-2005, 12:20 PM   #22
KyleYankan's Avatar
KyleYankan is on a distinguished road
I can't figure out Girder. I used the included Ir program, and it worked, but it thought every button was the same. The LED's in my IR receiver showed up (so it was connecting to COM1), but it wasn't receiving any data. I'm thinking if I gut the IR reciver and add one of those circuits, it might work.
KyleYankan is offline   Reply With Quote
Old 07-05-2005, 01:20 PM   #23
Terminal flasher
please forgive the super noob when it comes to serial port wiring but i'm having trouble reading the above diagram. According to what i see pins 2 and 4 dont connect to anything? and the connected pins are 1 & 3, 7 & 8, 5 & 9? Then 5 & 9 are both connected to ground... correct? I just wanna be sure before i end up fryin components.
Old 07-05-2005, 01:40 PM   #24
mox
mox's Avatar
Correct.
Yes. Crossing lines don't touch each other, unless the crossing is a dot.
Hope this helps -- good luck!
Software: RR, MM/FD
Old 07-05-2005, 04:22 PM   #25
Terminal flasher
thanks. Cant wait to get this accomplished now! I've got girder all set up!
Old 07-06-2005, 10:00 AM   #26
Terminal flasher
anyone else getting the error "unable to inicialize usb driver dll library" with the igor plugin? I've searched the net for solutions and i cant seem to find one.
Old 07-06-2005, 10:09 AM   #27
Terminal flasher
nevermind.. had to configure the plugin thru girder.
Old 07-06-2005, 03:01 PM   #28
mox
mox's Avatar
Yeah, it's a matter of selecting COM1 or 2 instead of USB.
I have just finished installing Girder on my MII-12000 based carputer (earlier testing was done on laptop) and it works fine. What is the latest and/or most complete GML-file for RoadRunner?
Software: RR, MM/FD
Old 07-07-2005, 09:13 AM   #29
Terminal flasher
there's a sticky in the road runner section with gml's. Dont bother downloading mine its probably a little too basic.
One LAST question on doin this. Now granted i havent cracked opened my lilli case, but i was wondering if i already have my infrared sensor remotely mounted, can i just splice into those wires instead of soldering directly to the board? This would save me alot of time and prevent having to crack open that touchy case again.
Old 07-07-2005, 05:51 PM   #30
Letsride is on a distinguished road
Mox can this be used without the screen ie; If I can buy just an eye and have it connected to the serial port?
Also...where can I get an eye?
Letsride is offline   Reply With Quote
help with a hardware hack! hijinks21 Off Topic 3 10-27-2007 03:07 AM
hardware not playing nice cyber General Hardware Discussion 2 07-27-2004 11:13 AM
Couple of nice Hardware Sites... hansolo77 General Hardware Discussion 1 06-26-2003 09:04 AM
Nice info for FV24 owners. moahdib Software & Software Development 8 02-14-2002 02:12 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
