Old 06-13-2005, 08:19 PM   #1
mox
mox's Avatar
mox is on a distinguished road
Nice little infrared hardware hack for Lilliput owners
I really felt like sharing this one -- It has turned out to be VERY easy to hookup the lilli's internal infrared sensor to your carputer's serial port. It will allow you to control your PC with whatever infrared remote control you have lying around, including the otherwise useless remote that comes with the lilli itself.
All you need is a program like Girder (www.girder.nl), an unused serial port, a 9 pin female D-sub connector and a single shielded wire. Girder has become payware, but earlier free versions can still be found. I got mine from http://www.gibbsdesign.co.uk/support/girder329.exe (Thanks, BenG )
Ok, as for the hardware, open up your lilliput, locate the infrared "eyeball" and solder your shielded wire to the 2 pads as shown in the picture below. Wire up the D-connector accordingly and that's it. The lilli eyeball is very responsive to whatever remote I'm firing at it, so you might prefer this hack instead of building your own interface from scratch.
Girder requires a well known plugin by Igor Cesko, which can also be found on BenG's site (http://www.gibbsdesign.co.uk/support/IgorPlug.zip). I find Girder to be a bit difficult to configure, but that's merely due to its versatility. There are plenty of howto's available. Igor Cesko's page http://www.cesko.host.sk/girderplugin.htm is a good place to start.
Enjoy!
CarPC status: HW all done, SW needs tweaked.
Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
Software: RR, MM/FD
mox is offline   Reply With Quote
Old 06-13-2005, 08:39 PM   #2
My man uses Levitra.
Peoples's Avatar
Peoples is on a distinguished road
you are the man.....but now i'll have to open my lilliput , oh well this will save me a good $20-$30
PC Components:
My work log
Peoples is offline   Reply With Quote
Old 06-13-2005, 08:40 PM   #3
Peoples's Avatar
one thing bothers me though.......why dont we see a picture of yours already soldered?
PC Components:
My work log
Old 06-13-2005, 09:06 PM   #4
mox
mox's Avatar
If you insist -- the bottom pic is a screenshot of Girder after teaching the mute button of the lilli remote. Also notice the orange leds to match my dash lighting.
Software: RR, MM/FD
Old 06-13-2005, 09:17 PM   #5
Peoples's Avatar
nice
PC Components:
My work log
Old 06-13-2005, 09:39 PM   #6
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
sweet
thanatos106 is offline   Reply With Quote
Old 06-13-2005, 09:46 PM   #7
RS3RS's Avatar
RS3RS is on a distinguished road
Awesome!
My blog on supercars and stuff
RS3RS is offline   Reply With Quote
Old 06-13-2005, 10:09 PM   #8
mox
mox's Avatar
Quote: Originally Posted by RS3RS
Awesome!
Notice the wiring being different from http://www.lirc.org/images/schematics.gif. Forget about that Lirc interface. The ones on Igor's page won't work either. The link between pins 1 and 3 is essential.
Girder is so cool -- I am controlling mplayer with the remote of my 15 year old vcr as we speak
Software: RR, MM/FD
Old 06-16-2005, 07:51 AM   #9
Peoples's Avatar
suprised this thread isnt getting more attention.....was hoping someone else would do it before I got around to doing mine
PC Components:
My work log
Old 06-16-2005, 08:20 AM   #10
Cheekz185 will become famous soon enough
Does any1 know if there is something like this for the Xenarc 700tsv?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Cheekz185 is offline   Reply With Quote
Old 06-16-2005, 09:11 AM   #11
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
what functions can say.. .the lilliput remote perform when connected to the computer. I guess i'm just a little confused as to whats to gain here.
Old 06-16-2005, 09:15 AM   #12
Marsupial's Avatar
Marsupial is on a distinguished road
nice turnaround - using the stock part for custom apps...
there should be a similar hack to xenarc or any other device with an IR eye...
http://www.modasylum.com/guides.php?guide=16
what's to gain from a remote in the car?
well, control the PC differently, even have specific buttons do SERIES of action.
if you want to do it, you can. You should give a try to Girder and figure out yourself... but be aware: once you start remote controlling your PC, there's no way back.
-Mars
Carputer progress meter:
[----------] - 0%
status:
Changing project. The kiosk I have will end up in the kitchen! Reviewing carPC ideas...
Marsupial is offline   Reply With Quote
Old 06-16-2005, 01:13 PM   #13
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
You don't use the lilliput remote you use any other remote with more buttons that can be programmed to to go things, anything with girder
antimatter is offline   Reply With Quote
Old 06-16-2005, 01:35 PM   #14
Banned
xdjxklusivex's Avatar
xdjxklusivex will become famous soon enough
nice!! :-( i just dont have a serial port sighh
xdjxklusivex is offline   Reply With Quote
Old 06-17-2005, 06:18 AM   #15
mox
mox's Avatar
What could possibly go wrong? I mean, if the hack would involve flashing some custom made bios or whatever, I would hesitate too. But there's really no risk in linking a simple 5V open collector output to a serial input which was originally designed to handle voltages between -12 and +12V.
Here's an image of the lilli's IR output, taken with a storage scope. Vertical scale is set at 2 volts/div, ground level is at the vertical center. Maybe this will boost your confidence
Software: RR, MM/FD
help with a hardware hack! hijinks21 Off Topic 3 10-27-2007 03:07 AM
hardware not playing nice cyber General Hardware Discussion 2 07-27-2004 11:13 AM
Couple of nice Hardware Sites... hansolo77 General Hardware Discussion 1 06-26-2003 09:04 AM
Nice info for FV24 owners. moahdib Software & Software Development 8 02-14-2002 02:12 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
