06-14-2005, 05:56 PM
#1
Grrr, why does my Xenarc Brightness and contrast keep reverting to 33 when I shut dow
Is this normal for everyone. It's driving me crazy.
Its not the cards you're dealt, its how you play the hand!
Quote: Originally Posted by ryuandwings
Where can I get a roll of tin foil?
I been looking for that all over the net, but I can't find it.
Please help.
06-14-2005, 11:36 PM
#2
doesn't always happen with me, but occurs more often than not....doesn't really bother me since i've learned to live with it
06-15-2005, 10:24 AM
#3
Xenarc has a fix for it. They need to update it. The new Xenarcs do not have this problem. I had my older Xenarc fixed by sending it in to them. Get an RMA # and return it!
06-15-2005, 04:41 PM
#4
Um, it's molded into my dash. Maybe I'll try to live with it.
Please help.
06-17-2005, 03:15 PM
#5
Raw Wave
I just ordered/received a new Xenarx, and it has the brightness bug. Damn!!!!
Will Xenarc repair this considering that I already removed the warranty seal when opening the case ?
06-17-2005, 03:29 PM
#6
FreeDrive Creator
yeah mine has the same bug and also has a single pixel out.. thought xenarc were better quality than this.. might just be a one off, but as I've taken my to pieces to mould it in.. there goes any return policy
CdR
07-28-2005, 02:31 PM
#7
I got a new Xenarc and it also resets the brightness etc to "default" settings when it loses power.
I talked to Xenarc about my previous screen (which was stolen) and they issued me an RMA# and I sent it in to them. They claimed there was a fix for it. I never got to try it out after it was fixed though since it got stolen
07-28-2005, 02:43 PM
#8
Son of a *****! I have had the same problem before, too- but haven't noticed it lately. I DO have an issue where my AV2 settings aren't retained, either. I think that it would only make more sense to retain brightness/contrast settings in the case of an external DVD player/backup cam/whatever.
Mine is in my dash, too- which makes it extremely inconvenient to remove to ship back...f%&k this is aggravating
To the mp3car STORE: Can you do anything to help me with this? I purchased from you and was unaware of a Xenarc issue. Perhaps I need to obtain an RMA number?
CarPC #3: 99% CompletePentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more! old carPC
07-28-2005, 03:19 PM
#9
I just got off the phone with Xenarc
Jimmy confirmed that the "old" models do not remember contrast/brightness etc settings. They can issue an RMA to fix it like they did to my last model. My old model was purchased about a year ago from now and it had the problem.
He said the new model I just purchased should NOT have the problem - it should remember contrast/brightness settings even when power is removed.
07-28-2005, 03:47 PM
#10
there are two issues with some older xenarc:
1. The brightness reverts to default.
2. The screen picture does not align
3. The touchscreen doesnt work randomly
Remedies:
1. Make sure the power is always connected to the battery...a constant 12v. The screen will turn off when the computer is off.
2. HAVE NO IDEA, it sucks
3. http://www.mp3car.com/vbulletin/show...ghlight=xenarc has the info on touchscreen seperation
DICE Los Angeles
07-28-2005, 05:29 PM
#11
keeping constant power is a possible workaround, not a solution...
500+ full albums
4,000+ video games
07-28-2005, 06:57 PM
#12
I have mine hard wired to full time 12v, it still reverts to the 33 brightness once a week or so. Once I had it lock up with a blank screen. None of the buttons worked includding the power button. I had to pull my dash cover to remove power to get it working. If you wire it up to have power all the time, you should have a way to kill power to it if you need to.
07-29-2005, 01:48 PM
#13
You should have a fuse near your power source...This would suffice.
500+ full albums
4,000+ video games
07-30-2005, 12:21 PM
#14
Do they replace the whole screen, or is it just a firmware update?
07-30-2005, 06:14 PM
#15
It is just a firmware update
| Thread Tools |
| Display Modes |
Linear Mode
