Old 06-17-2005, 11:48 AM   #1
lilliput calibration failed??
I just got my lilliput in the mail the other day and I was playing around with it last night and for some reason I can’t calibrate the screen when I do the 4 point it goes to the touch the x till it stops blinking thing…..I do that it keeps blinking till the yellow bar fills up then it tells me that the calibration failed…
Am I doing something wrong the screen works fine right now the calibration is slightly off but no big deal but it could be a big deal in the future.
nomorspam is offline   Reply With Quote
Old 06-17-2005, 07:44 PM   #2
anyone?
Old 06-17-2005, 07:51 PM   #3
Para Laura
thanatos106's Avatar
So you touch the X in the left buttom corner but it doesn't reconize that you touching it??
Do you even see the other X ??(is one X in every corner)
If the yellow bar goes all the way from one site to the other is that the TS is no working right..
More input please.... (maybe is a conection failure/power failure or something else)
thanatos106 is offline   Reply With Quote
Old 06-17-2005, 09:00 PM   #4
that is correct
Yes 1 X in the bottom left and if I go to the 24 point it shows a bunch of Xs (I'm guessing 24...but didn't count them)
it's odd cus the touch screen works fine other than that??
Old 06-17-2005, 09:08 PM   #5
markland556's Avatar
make sure you have the drivers installed for everything, same thing with mine, just needed to put the drivers for the "mouse" controller on the screen.
86' Mercedes 300E
Status..::... {######----}65%~~ paused
markland556 is offline   Reply With Quote
Old 06-17-2005, 09:13 PM   #6
Para Laura
[quote=nomorspam]that is correct
Well I think something is wrong with what you saying:
When the firt X appears and start flashing you have to touch it and it will beep then it show you the next one (if you see the others it means that the TS reconized when you touch the firts) I thought you said that you using all the time and that you see the yellow bar going front left to right (that thing is just a counter that is counting the time that you have left to touch the x)
So if is no PW or a connection problems just desinstall the drivers and get the latest version and reinstall them again.
Hope you that you can fix it.
Old 06-17-2005, 11:27 PM   #7
found new drivers and all is good...now just to get the stinkin thing in my car
http://www.egalax.com/support-drivers.htm
Old 06-24-2005, 03:09 PM   #8
carabuser's Avatar
did you install 4.0.2... drivers and now it works? I have 4.0.2 right now and have the same problem.
2000 Maxima CarPC
Current Status: Rebuilding
Specs
- 1.5Ghz Toshiba Laptop
- Indash Motorized 7" VGA TS
- DeLorme GPS
- Power Inverter
- Pioneer HU
carabuser is offline   Reply With Quote
Old 06-30-2005, 10:41 AM   #9
Snootch's Avatar
I just figured that one out after getting mad for about an hour, and re-installing drivers.
You have to touch AND HOLD DOWN the flashing X, just touching it won't work.
WORKLOG
VIA SN18000/1Gb GEIL PC3200/100Gb 2.5"HD/8" Phylon TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Lilliput often needs calibration cyrix^ LCD/Display 10 06-10-2005 03:53 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Lilliput Calibration WAY off ismell LCD/Display 18 06-08-2005 02:21 PM
Lilliput Touchscreen Calibration - WORKED FINE - Then.... Mrbmw99 LCD/Display 11 11-15-2004 09:30 AM
Lilliput 4-point and 25-point calibration? chris in nh LCD/Display 3 06-20-2004 02:16 AM
