Old 06-20-2005, 05:43 AM   #1
John_Duh's Avatar
John_Duh is on a distinguished road
DWW - 700M : not opening
hello guys,
This weekend my screen arived ... but as the title already suggests, i couldn't open the screen.
I powered it off an ATX PSU from my computer and it turned on perfectly. I could set the time on the small display, but when pressin the open-button nothing happened. Oh yeah, i fed it a display signal off my laptop through the 15 pins connector cable that came with the display.
Any suggestions ? Did i miss something ?
'02 Toyota Celica TS
Carputer progress : [#######---]
Currently working on : software ...
Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
Parts needed: USB wifi dongle (with external antenna)
John_Duh is offline   Reply With Quote
Old 06-20-2005, 06:39 AM   #2
dan__wright's Avatar
dan__wright is on a distinguished road
someone posted something similar, you have to connect the red and yellow wires that arnt connected to anything to themselves i think, its for a handbrake sensor so you can use the screen while your driving.
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
dan__wright is offline   Reply With Quote
Old 06-20-2005, 06:56 AM   #3
John_Duh's Avatar
can you be a bit more specific ... or maybe give me a link ?
I did a quick search but couldn't find it (and since i'm at work i can't search for hours)
On the screen's power connector there are 4 wires
- 12V (yellow)
- ground (black)
- earth (red)
- lighting signal (green)
From your reply i undestrand that i should connect red and green together. Correct ?
TIA
Old 06-20-2005, 07:13 AM   #4
Raw Wave
Gobby is on a distinguished road
by the looks of it put black and red together, check the manual, it all depends on how the screen connects to the handbrake for its signal
Gobby is offline   Reply With Quote
Old 06-20-2005, 08:41 AM   #5
John_Duh's Avatar
The manual says ground or something crypitical for the red wire. I'll give it a try as soon as i get a chance.
Thanks for the help
Old 06-20-2005, 01:40 PM   #6
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Wiredwrx has a little shameless behaviour in the past
OH, MY , GOD. First of all, no one so far seems to know what they are talking about, including the original poster.
Somewhat correct, but nope.
- 12V (yellow)
- ground (black)
- earth (red)
TIA
Your wiring color is wrong. Green is no a "lighting signal"
While somewhat correct, when was the last time someone had to connect Black and Red to the same source. Convention dictates Black is ground, and Red is power. I realize you were using JDs wiring diagram for that statement, but still.
Phew, now I feel better.
The wires are Red, Yellow, Black, and Green.
Red is constant power, Yellow is accessory power (12 volts when the car is running, and nothign when the car is off), Black is ground, and Green is the handbrake switch.
You must ground the handbrake switch wire to get the unit to work. It can be connected to the Black wire, and both grounded to the same place if you like. Yellow and Red CAN be connected to the same 12 volt source, but they should be connected correctly to operate correctly. If you are just testing the unit, don't worry about it. The red supplies power to the unit all the time, that way when the Yellow wire loses power (From turning off the car) the unit still has a power source to close the screen.
Please, if you are unsure about something, state it is such, or research the answer. Just blindly giving advice can lead to trouble. And John, . While I agree that the manual isn't the greatest, the only real question is the green wire. Red, Yellow and Black are both explained in the manual, and pretty self explanatory.
Michael
Sorry for the rant, just don't want him to screw up his unit.
Also, you can check out my 700m modification thread at http://www.mp3car.com/vbulletin/show...ight=Motorized
Wiredwrx is offline   Reply With Quote
Old 06-21-2005, 03:54 PM   #7
John_Duh's Avatar
Michael
uhm ... well .. i did the RTFM thingy, but couldn't figure it out. And for the moment i really don't have a lot of time to try to decifer something cryptical like this manual. So I went for the easy option (you can flame me for it, but that's what i did)
And yes, i got the wiring colors wrong, but that makes two of us. The manual states that Yellow is constant power while red is switched. (or at least that's what i understand when they say "+" battery)
Anyway, Arwen jumped in and sent me a PM, so here is the correct connection for testing purposes to a normal ATX-PSU
yellow + red -> yellow PSU wire (12V)
black + green -> black PSU wire (GROUND)
don't know if it matters which ground you use, but i took 12-ground
Guess for in-car purposes that the connection should be as follows:
yellow -> battery +
red -> switched 12V
black -> ground
green -> ground (or handbrake if you don't want to open your screen while driving)
Thanks to Arwen for his support in this matter
Old 06-21-2005, 04:01 PM   #8
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
yellow -> battery +
red -> switched 12V
black -> ground
I apologize for confusing the Red and Yellow. I was going off memory. I just wanted to make sure you didn't connect red to ground, and green to +, cause that would undoubtadly have caused a problem in the unit, and certaily. black and red together to a positive source would have had the same ending, a broken unit.
Did you get it to work?
Michael
Old 06-27-2005, 11:07 AM   #9
John_Duh's Avatar
Michael
Same here (going off memory) ... seems we both need an upgrade
Yes, I got it to work ... now i only need to get my software sorted out and i can start thinking about installing it in my car
thanks for the support guys
Old 05-30-2009, 11:04 PM   #10
smanders
This seems like a very knowledgable group regarding the DWW-700M. Could you please check out this thread and provide some insight.
http://www.mp3car.com/vbulletin/lcd-...-dww-700m.html
Thanks so much!
EvoX CarPC (in progress)
Acer Aspire One, OpenPort 2.0 cable, 12V car power adapter, ignition timed relay to unused pins on Ethernet port
Rhapsody, EcoScan, EcuFlash and still trying to make up my mind
EvoVIII CarPC retired
smanders is offline   Reply With Quote
WTB: Lilliput Infared Opening Cover hussein Classified Archive 10 10-20-2004 01:52 AM
Anybody use this from DWW heartpumper LCD/Display 0 02-27-2004 10:08 AM
Can 7" touchscreen fit in double DIN opening? RDaneel LCD/Display 22 02-26-2004 02:53 PM
New opening mp3car.com page grandamp3 Mp3car Forum Suggestions/Comments 21 08-12-2003 02:22 AM
LCD Text Display for Din opening --Please Help... prerunnerv6 LCD/Display 9 09-24-2002 04:27 PM
