Old 06-23-2005, 08:58 AM   #1
djXternal's Avatar
djXternal is on a distinguished road
Rewiring IR on Lilli
Ok i'm installing my lilli into my sunvisor and have no room or need for buttons, all i need is the IR sensor to work.... I was wondering if you can use the one that came with it, just snap off the pieces of the board the buttons are on around the IR sensor and solder wires to the connections of the sensor...
or should i pick up another sensor some where, and if so what kind
thanks
Debating on installing a carpc in my Jeep.....
djXternal is offline   Reply With Quote
Old 06-23-2005, 09:00 AM   #2
dan__wright's Avatar
dan__wright is on a distinguished road
or just de-solder the ir reciever? you will prob end up ******* the whole board up if you try snap part off.
Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
Toys:K8055 relay board, Elmscan OBDII
Type-R Mini
dan__wright is offline   Reply With Quote
Old 06-23-2005, 09:04 AM   #3
djXternal's Avatar
ahh good idea, dont kno why i didnt think of that
Old 06-23-2005, 10:47 AM   #4
Banned
xdjxklusivex's Avatar
xdjxklusivex will become famous soon enough
yeah just desolder it dont snap it off its a ***** to desolder tho so have fun make sure u get the 3 wires connected right or it wont do **** for you test it before putting it in!!
xdjxklusivex is offline   Reply With Quote
Old 06-23-2005, 05:41 PM   #5
djXternal's Avatar
now, i know that...
PIN 8 = IR PIN 2
PIN 9 = IR PIN 3
PIN 10 = IR PIN 1
But i dont know which pin is labeled 1, 2, and 3 on the ir itself
anyone know which pins on the ir are wired to which pins on the ribbon connector?
Old 06-23-2005, 05:53 PM   #6
Jesus Freak
antimatter's Avatar
antimatter is on a distinguished road
follow it back on the pcb
antimatter is offline   Reply With Quote
Old 06-23-2005, 06:55 PM   #7
djXternal's Avatar
middle one doesnt seem to go newhere, and the others seem to goto 10, 11... and that doesnt follow the wiring guide that you posted in your write-up
Old 06-24-2005, 01:42 PM   #8
Jesus Freak
antimatter's Avatar
http://www.tmz.com/wrx/lilliputlcd.html
Old 06-24-2005, 01:44 PM   #9
Jesus Freak
antimatter's Avatar
Pin 8 Phototransistor Pin 2 (GND), Switch Common & LED Cathode (Red & Green Only)
Pin 9 Phototransistor Pin 3 (Vcc) and Blue LED Anode (all 7) Common
Pin 10 Phototransistor Pin 1
Old 06-24-2005, 02:06 PM   #10
Banned
dont tap it from there desolder the ir thingie from the board itself and extend it off the board its easier and safer!
Old 06-24-2005, 02:11 PM   #11
djXternal's Avatar
yea i desoldered it last night and put some wires on it, just gotta solder em to the pins on the main board now
Old 06-24-2005, 02:27 PM   #12
dudical266 is on a distinguished road
I tried to extend the sensor off the board but something went wrong and when i reconnected it, it never worked. Is it possible that the heat from the soldering iron mest up the IR reciever, if so where can i buy a replacement.
dudical266 is offline   Reply With Quote
Small IR receiver help to configure / creative remote jedi7001 General Hardware Discussion 2 05-30-2005 08:20 PM
Lilli only *half* broken. silencery LCD/Display 0 04-04-2005 03:00 PM
Lilli ghosting. Searched and still need help maxxell LCD/Display 1 03-24-2005 04:01 PM
I need a final word on IR receivers nsmoller Input Devices 3 02-06-2005 06:28 PM
Mobo IR connectors blkdragon6 General Hardware Discussion 6 07-07-2000 02:23 PM
