The MP3car.com Store
Thread Tools Display Modes
Old 10-21-2001, 11:51 PM   #1
My Photos: (0)
Post Seiko 4024 blocks on first and third
Okay, I know this has been posted a few times but here's the situation.
Got a 4024 (Same as 4034 for pinouts), connected it all up (double confirming everything) all I get is blocks on the first and third lines. LCD print does not even see that it's connected.
So what's the plan, where did I go wrong. I used Nathans revised pinouts and was about as paranoid as I could get with getting it right! Any ideas?
Thanks Tons.
Also the lcd get's quite after I've tried either lcdprint or another winamp plugin?
Thanks in advance, you guys are great!
Craig
keggers is offline   Reply With Quote
Sponsored Links
Old 10-22-2001, 05:04 AM   #2
Registered User
Raas's Avatar
My Photos: (0)
Post
When the display gets powered the 1st and the 3rd line are black blocks.. that should be okay.. each one does that.. The display waits for the first command to show on the display..
If you are absolutely sure about your wiring, you may have to check your parallel-port setup in the BIOS, it should be something like EPP or SPP.
Make sure you specify the right adres with lcdprint. If you don't, the display doesn't show anything.
If you have done all this, and nothing works, I think the display is broken, but since it displays 2 lines of block when you power it that won't be the problem (I think)
Hope this helps you out, and let us know !
Greetz
Raas - The Netherlands
ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
Raas is offline   Reply With Quote
Old 10-22-2001, 08:34 AM   #3
My Photos: (0)
Post
u have to change your parrallel port to ECP mode, or is that only for lorties plugin?
PaulzY is offline   Reply With Quote
Old 10-22-2001, 02:45 PM   #4
Live and Kickin'
Arby's Avatar
Vehicle: 2004 Mazda RX-8
My Photos: (0)
Post
You also need to be running win 98 or 95, it won't work in win2000 or NT.
I'm not sure about ME or XP, though.
www.arbybean.com
Arby is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Sponsored Links
Ad Management by RedTyger
