Quote:
I dont know how much thanks you get but I noticed that you are very active when it comes to helping people on this board. Sooo Thanks.
Not much, but I don't do it for the gratitude
but thanks for thanking me, if for nothing but the sheer change of pace!
Quote:
telek: you do realize standard monitors are analog, and that they have like .24 dpi resolution. just for fun, I just took my 17" monitor and made the image as small as possible, and it went to about 5"s completly readable.
Yes, standard monitors are analog, but they're also designed specifically to work off the VGA analog output. Monitors also tend to have small dpi resolution, like you said. The thing with monitors is that the grid that you display the image on is very fine and the beams don't need to be to horribly exact to get a sharp picture. When you're dealing with an LCD screen, it has to interpret it into digital mode first, and the interpretation isn't exact, so you'll get things like 1 logical pixel smeared over 2 actual pixels, it's not pretty.
There are 3 LCDs that are viable for use in a car that aren't hideously expensive. LCDs that take a simple RGB input and display like a TV would, LCDs that work off of the VGA signal, and then actual digital LCDs like the ones I mentioned from earthLCD. The prices increase in that order as well.
If you expect to be able to use a 5" TV LCD with a TV output from your computer at 640x480, for actually using the computer, good luck. Everything is going to be very blurry, and text won't show up very well at all. (the reason why this is worse than VGA is the way that it's interpreted, the actual physical number of pixels in the display, and you also need to use a VGA->TV circuit in your computer which also degrades the quality of the image)
If you have a 5" VGA input LCD then you're one step up, but it's still going to be blurry.
From what I can see, if you want to be able to use the computer through the LCD for just about anything, you're going to need at least a 6.4" digital or 8" analog input LCD screen at the prices and the qualities that we're talking about. If you can get a GOOD digital input LCD, 5" can do for 640x480. Don't forget as well that you're not going to be 3" away from the screen. This screen needs to be *easily* readable from a foot or so away so that you don't hit a tree while trying to read what's on your screen.
The Datalux screen is 0.47dp diagonal, and most LCDs in this price range are going to be something like that. With dp's like that you'll need a fairly big screen to be able to easily use your computer.
