Old 10-25-2001, 07:54 PM   #1
Post 5v power?
on jeffs site i read
"Most parallel ports do not supply enough power to operate an LCD. I decided to use the keyboard connector to power my LCD. I have a cable that goes from the keyboard connector to the parallel port connector, and then a cable that goes from the parallel port connector to the display"
I looked on his site, and couldnt figure out how this is done? Are you able to do what he did if you use a keypad connected to your AT 5-pin DIN port? the lcd i plan on using is the 40x4 one from arby. thanks (and btw i tried using the search tool, just couldnt find anything.)
thanks,
dave
theMP3RUNNER
car|'93 4runner 3.0l v6, aiwa cdc-x317 head unit with aux-in
carputer|pentium 133mhz, 40mb ram, 7.24gb hard drive, system blower pci/isa fan, 800w peak ac inverter, 40x4 backlit lcd
daver is offline   Reply With Quote
Advertisement Sponsored links
Old 10-25-2001, 10:03 PM   #2
Post
here is a power tap from the keybaord connector is has the power tap and a keyboard pass thru so yo uowuld be able to have the power and a regular keybaord (I have never used anything like this I know know where to find some things) so I am unable to tell you anything more about it.Compgeeks AT power tap
Compgeeks PS/2 power tap
moxnix is offline   Reply With Quote
Old 10-25-2001, 10:04 PM   #3
Post
Can't you just use the 5v supplied by your power supply?
http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
Maveric is offline   Reply With Quote
Old 10-25-2001, 11:07 PM   #4
Post
they are all used up
theMP3RUNNER
Old 10-26-2001, 12:21 AM   #5
Post
just split it daver. 5 volts from the keyboard is gonna be no better/worse then 5 volts from the PSU. Just cut into one of the 5volt wires from your psu....
Project - GAME OVER :(
magnetik is offline   Reply With Quote
Old 10-26-2001, 02:04 AM   #6
moahdib's Avatar
Post
I use a 7805 voltage regulator to power my 40X4 LCD. Just add a heatsink and it will give you 5V@1amp max. It looks like this...
____
|___|
1 2 3
1 connects to 12V
2 is ground
3 is your 5V output.
make sure you use a heatsink though otherwise it will get hot and might blow up hehe
04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
Fast car, fast PC. ;)
http://www.arcdesigns.net/carpc/
My TL CarPC ver2
FSR Flash Skin w/ moving weather maps
moahdib is offline   Reply With Quote
Old 10-26-2001, 07:27 AM   #7
dbinnc's Avatar
Post
what can i use to get 12v@1.5 minimum?
Site dedicated to the 7th Gen Honda Civic
FKA 2k1civic.com
dbinnc is offline   Reply With Quote
