5v power?
on jeffs site i read
"Most parallel ports do not supply enough power to operate an LCD. I decided to use the keyboard connector to power my LCD. I have a cable that goes from the keyboard connector to the parallel port connector, and then a cable that goes from the parallel port connector to the display"
I looked on his site, and couldnt figure out how this is done? Are you able to do what he did if you use a keypad connected to your AT 5-pin DIN port? the lcd i plan on using is the 40x4 one from arby. thanks (and btw i tried using the search tool, just couldnt find anything.)
thanks,
dave
theMP3RUNNER
car|'93 4runner 3.0l v6, aiwa cdc-x317 head unit with aux-in
carputer|pentium 133mhz, 40mb ram, 7.24gb hard drive, system blower pci/isa fan, 800w peak ac inverter, 40x4 backlit lcd
