Old 09-25-2001, 04:12 AM   #1
Registered User
Question 1x 40 backlit LCD??
Hi all,
I was just wondering if there is such a thing and if so where I could find one. The height is an issue here, since I intend to use this LCD as a backup for my TFT when it's folded in the dash, so a LCD which height is about the thickness of my TFT, say a bout 1cm or 0,5 inch...
cheers!
If at first you don't succeed.........
destroy all evidence you tried
for info on t6369c LCD or Presslab's powersupply check:
http://www.namms.tk <=updated!!
marsjell is offline   Reply With Quote
Advertisement Sponsored links
Old 09-25-2001, 08:36 AM   #2
Registered User
Raas's Avatar
Post
Hi Marsjell
Wow.. now that's gonna be a small display..
Don't you have any casing around the tft ? I guess it would be a bit thicker when you've got some casing around it..
Anyway.. them smallest display I found at eio was 30mm wide (2x40) so I guess this is too wide for you...
However Densitron LCD have got 1x40 lcd's (LM4131) but they're 33mm wide.
But it sure is an nice idea !
Keep us informed !
Greetz
Raas - The Netherlands
ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
Raas is offline   Reply With Quote
Old 09-25-2001, 10:28 AM   #3
Registered User
Post
The casing it what makes it +/- 16mm the TFT is only 8mm, I'm using 2,5mm plexiglas(is this english? ) for the "front" and 4mm for the back. I wanted it all to be as compact as possible... thanks for the link BTW, I looked at a couple of LCD's and I noticed that the case for each LCD makes the outside dimensions about double the viewing height, isn't there a manufacturer who puts the electronics behind the LCD instead of above and below it? I don't care about the thickness of the LCD....
Old 09-25-2001, 11:56 AM   #4
Post
Timeline has some 1 character high LCDs (both 16 X 1 and 40 X 1) but they don't list dimensions on their site. Might be worthwhile to give them a call.
mtmsol is offline   Reply With Quote
