Quote: Originally Posted by
Custom
Hi,
I have the same problem with the touchscreen, i own a Xenarc 700TSV. I also have problems with IBUS adapter, after a period of time its not working, i have to reboot the system to make it work again.
Any advice ?
Thanks,
I am using Xenarc Touchscreen and I-Bus as well.
I had similar problems untill last weekend. Sometimes I lost my touchscreen during driving in 10 minutes, sometimes in 50 minutes but fact was fact - something did not work right in my system.
Is your I-Bus interface conneted thru hub ? Is your Xenarc touchscreen connected thru hub ?
In my case everything (I-Bus and Xenarc + another Com to USB adapter (for OBD) were connected thru one hub. All what I did was: For xenarc touchscreen I put one extra USB extension directly to motherboard. For my I-Bus I just swithced it to COM port instead of using thru USB (but I am sure the problem was with this USB Hub).
Some one tol me that it is very bad idea to connect Xenarc Touchscreen and what ever else (what use COM port) in the same HUB and the guy was right. Now my touchscreen works just fine as well as I-Bus.
Hope it will help. If not than I will sugest you to check/reinstall drivers for touchscreen and also to check your connections.
Goodluck
Vinzer
