Old 07-05-2005, 10:55 PM   #1
High Voltage
blk02si's Avatar
blk02si will become famous soon enough
Question Xenarc and extreme tempatures
Hello,
Im new to the forums and I gotta say, you guys rock!! I finally have a resource for my computer and car addictions. Anyway Im building a carPC and was looking into the Xenarc 7" touch screen. I live in Michigan and we see everything from 95 degress to 10 below in the winter. Im more worried about the cold than the heat. Im wondering if anyone has exposed the Xenarc unit to these extremes and if so the performance or lack there of under these conditions. Thanks for any help/reviews.
blk02si is offline   Reply With Quote
Advertisement Sponsored links
Old 07-05-2005, 11:00 PM   #2
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
Well I live in miami beach...... and I have a xenarc, the screen works fine.
BTW i'm running 2 40mm fans in the back.
Good luck with you new project.
Thanatos
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 07-06-2005, 01:24 AM   #3
Para Laura
Quote:
Hey how did you wire up you 2x 40mm fans in you LCD Screen?
I just got one of those HD coolers and put the fans in the back of the screen (they are screw to the screen bracket) and then I just use the acc line to get power.
Ok .... cheeckz185??
Any other question please use the threads...
Thanks.
Thanatos
Nissan Aux-in MOD
Old 07-06-2005, 01:41 AM   #4
Cheekz185 will become famous soon enough
so u basically just removed the HDD fans and mounted them to the back of the LCD?
Cheekz185 is offline   Reply With Quote
Old 07-06-2005, 01:42 AM   #5
Para Laura
yeap.....
Nissan Aux-in MOD
Old 07-06-2005, 01:44 AM   #6
you put them where the speakers are on the lcd? and were you able to put the backing of the LCD back on?
Old 07-06-2005, 01:46 AM   #7
Para Laura
no inside............ out side the screen!!!!!! I never open my screen and I think I never will..
Nissan Aux-in MOD
Old 07-06-2005, 01:48 AM   #8
gotcha!
Old 07-06-2005, 01:40 PM   #9
Auxon is on a distinguished road
I just installed my xenarc last week and am dealing with the hot temperatures here in Boston. What I've experienced is that the screen will not work at hot temperatures, either fails to display any image or displayes a garbaged one if any. Once the screen has cooled down via air conditioning, being put in the fridge, or whatever, it returns to normal operation.
I'm sure heating it and cooling it isn't good for it, but I haven't found a good alternative yet.
Aux
PCChips M789 v3 w/ Samuel 2000+ S3Vid Lan AC97, 40 GB 7200PRM, 512 DDR266, Xenarc 700YV, PAC AAI-GM9 Headunit Adapter, Sirius Sportster, touchpad mouse input.
Auxon is offline   Reply With Quote
Old 07-06-2005, 01:45 PM   #10
What about just turning up the AC?
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Old 07-06-2005, 02:01 PM   #11
knubile's Avatar
knubile is on a distinguished road
I live in Ottawa, Canada and see -30C during the winter. Not sure how cold it actually gets inside the car, but it's definietly worse than Michigan. The worst I've seen is a slow redraw rate on the screen. It's never stopped working for me.
I think it's pretty good for the winter. I've never had an issue besides the slow redraw that only last the few minutes until the inside of the car is at a decent temp again.
knubile is offline   Reply With Quote
Old 07-06-2005, 02:02 PM   #12
High Voltage
blk02si's Avatar
Im talking about when it sits overnight or something. Or if its buried in snow for a couple days. How do extreme temps effect the life/ quality of display, ect.
Old 07-06-2005, 02:57 PM   #13
Para Laura
Aux
Well thry the fans solution...... you can try 80mm if you think that 40mm are to small.
We just reached 110 (Inside the car) yesterday and the screens haven't stop to work.
Thanatos
Nissan Aux-in MOD
Extreme Newbie to Carputers TheLadiesMan Newbie 5 01-08-2005 01:06 PM
Xenarc 700TSV 800x480 Support auto_robotics LCD/Display 7 08-27-2004 01:33 PM
