Old 07-12-2005, 08:25 PM   #1
Speg's Avatar
Chopping up a heat sink
Is this as simple as I think it is? Chop up a heat sink into the sizes of the chips on the back of the monitor, stick them on, and have a fan blow air away or on them?
This should keep the chips a bit cooler?
OR am I out in the woods on this
Speg is offline   Reply With Quote
Old 07-12-2005, 08:53 PM   #2
Mad Ad's Avatar
should do - that is assuming you really need the cooling. I use individual ram heatsinks for any pcb chips i need to cool (come in a pack of 8, each one is the size of one individual ram chip)- i cut them in half for smaller chips like for videocard memory, or motherboard chips (had a dodgy network controller once, used to be the first thing to crash in the heat till i glued on of those on).
They come with sticky pads though, no good at all- scrape them off, clean off all traces of glue and use arctic silver epoxy
http://www.arcticsilver.com/arctic_s...l_adhesive.htm
fantastic stuff.
Mad Ad is offline   Reply With Quote
Old 07-13-2005, 09:49 AM   #3
Speg's Avatar
Sweet!
Reason being because I used to have the Lilliput plugged into the cig lighter. But day time I found the screen dimmed plus sometimes the picture went all scrambled when signal light was turned on or whatever. So I read and I figured 2 reason
1: Not a constant 12V going to the screen
2: Over heating.
So last night I wired the Lilliput to the OPUS and it was definitly brighter! Me like But I am afraid now that heat "could" be a factor and with this constant higher power, I wouldn't want anything to over heat. So heat sinks on the chips and a fan to blow some air on them from the air vent to keep them cooler. That should be safe.
Now, weather to buy or cut the processor one up :P
Thanks!
m1-atx heat issue neon_eddy Power Supplies 5 06-01-2005 06:19 PM
Voltage Regulator Constant Heat phita23 General Hardware Discussion 17 02-21-2005 01:18 AM
Low profile AMD XP 2500 heat sink (no fan) Arathranar General Hardware Discussion 4 01-08-2005 05:15 PM
To heat sink or not to heat sink ... jnusaira Newbie 5 02-18-2004 10:46 AM
CPU Heat question: Which one would generate less heat? kiztope General Hardware Discussion 6 02-12-2004 03:14 AM
