Old 02-01-2002, 06:49 PM   #1
Registered User
Tech^Cellfish's Avatar
Tech^Cellfish
Question Trouble w/ char LCD
My LCD is a Shelly 41602THB-G display. 16x4 backlit display. It has 15pins and a HD44780 chip.
I have wired it up like OcMods show here. With no resistor and the contrast is directly wired to ground.
My problem is that NOTHING showes up on the display. I got LCDisplayer to work, and LCDPRINT.EXE seems to work ok.
While checking the data lines, it seems like D7 (Paralell port pin9, LCD pin 14) never hits 5V like the other data lines that changes between 0V and 5V. D7 changes between 0 and 1,5V.
I thought my port was messed up and wired up a printer card. The card showed up win98 and both programs stated above seem to work. But nothing shows up on the display. All wires goes through my printer cable / DB25 connector. BTW: the backlight works!
Any ideas what could be wrong??
Car: 1995 Saab 900S 2.0 ,Sapphire GPS ,Mini-Mag WiFi antenna
HU: Pioneer DEH-P7100R AMP: XM-4060GTX Sub: XS-L121P5
Old car that got stolen: 1984 Nissan Cherry (Pulsar), PII-400,64MB Ram,35GB HD,Keypad,CF 634 Display
Tech^Cellfish is offline   Reply With Quote
Advertisement Sponsored links
Old 02-01-2002, 07:35 PM   #2
Rob
Registered User
Rob's Avatar
Rob
Post
First don't worry about D7, the data sent to the LCD is all in ascii, and the highest value you'll use is, z which is 122 or 01111010
Also when it's powered up, and there's no control software running, do you get black boxes on the screen, if you don't then it's going to be a problem with the contrast.
I hope that helps, a bit.
Rob
And you say people actually pay money for M$ Windows?
www.mp3mini.co.uk (Does what it says on the URL) www.openclassic.co.uk (The new car, with zero rust!) www.rob-web.co.uk (My other site)
Total re-design underway: on the whole progress is very slow as the car is taking up too much time :)
Rob is offline   Reply With Quote
Old 02-02-2002, 09:22 AM   #3
Registered User
Tech^Cellfish
Post
I get no black boxes. Is that standard on all HD44780 displays?
Maybe I'm able to dig up a potmeter to try and adjust the contrast. Thanks for the help.
Old 02-02-2002, 03:15 PM   #4
Machs_FueL
Post
I know this is completly off topic, but whats a Nissan Cherry?
[SIZE=1]'91 Nissan Stanza
[XXXXXXXXXXXXXXXXXXXX] XX% Completed -
Car Totaled and i bought a 20G mp3 player
http://machs-fuel.tk
a DIY video projector page
Machs_FueL is offline   Reply With Quote
Old 02-03-2002, 12:00 PM   #5
Registered User
Tech^Cellfish
Post
It's my car. a Nissan Cherry. (earlier models are made by Datsun, but thank god mine is a Nissan). My sig is wrong, because it is a 1984 model, not 1986 as I first thought.
Old 02-04-2002, 10:45 AM   #6
Meatballman's Avatar
Meatballman
Post
In the United States it is known as the Nissan/Datsun Pulsar:
http://www.cherry.nsb.pl/?l=en
http://www.geocities.com/motorcity/1415/
[ 02-04-2002: Message edited by: Meatballman ]
Meatballman is offline   Reply With Quote
Old 02-04-2002, 02:26 PM   #7
Registered User
Tech^Cellfish
Post
I tried to solder on a potmeter. It didn't change how things worked. I did also try to feed the display with 5V/Ground through regular cables, instead of through the signal cable. But it didn't help..
Seems strange that nothing is visible on the display. I don't think it is broken, as I bought it new off eBay.
Anyone have any ideas?
