Old 08-03-2005, 07:30 PM   #346
Quote: Originally Posted by Cravex7
Lol, well I've priced up a return and the cheapest I've found is £36, so I think I'll send it back and get a standard lilliput touchscreen instead.
Have thet agreed to that then.
regal is offline   Reply With Quote
Old 08-03-2005, 08:04 PM   #347
Try using the remote to get out of radio mode?
BikeBoy24 is offline   Reply With Quote
Old 08-03-2005, 08:12 PM   #348
Tried that, when I turn the ignition on the blue lights come on and it’s locked on FM, no buttons work at all.
When you use your remote can you see the little neon light flash.
Old 08-03-2005, 08:18 PM   #349
Is the button stuck or something?
Old 08-03-2005, 08:32 PM   #350
They all seem free
Old 08-03-2005, 08:34 PM   #351
This is exactly what happened to Carvex when he got his.
I’ve just wrote back to ex-audio steaming mad as you can imagine
Old 08-03-2005, 10:06 PM   #352
Damn regal that sucks. I haven't checked out if my touch screen works or not. I was hoping to get my alarm installed Friday an then put the unit in either Saturday or Sunday. I am scared the that the touch screen isn't going to work now. I'm going to cross my fingers....
blackflux is offline   Reply With Quote
Old 08-03-2005, 10:13 PM   #353
The PC and TV mode worked fine apart from the touch until I pressed the radio button, that’s when it stops working, I would suggest using it in every mode for a day then try the radio and see what happens.
I hope yours is OK.
Old 08-03-2005, 10:25 PM   #354
Raw Wave
kickercivic1's Avatar
is there a reset button on this unit????? I just think in all this unit, all the problem you guys have it becuase of software. I bet the software that runs the thing is not made right.
07 Jetta
Carputer:
Voompc-2, Intel 1.33, 1GBram, 60gb HD, Dynamix 8"
Audio:
front Qsd 216
Rear QSD 213
Rockford (2) p2 10" subs
JL 500/1
JL 300/4
Audigy 2 nx
kickercivic1 is offline   Reply With Quote
Old 08-04-2005, 12:07 AM   #355
You can unplug the cables from the back to reset.
spdyscotty is offline   Reply With Quote
Old 08-04-2005, 04:56 AM   #356
Tried that as well with no luck, I left it unplugged over night and just tried it again but nothing happens, its still comes up saying FM radio but it won't do anything , none of the buttons will work not even on the remote.
I still think this unit was a return, because the case had dirty protective film stuck on it, the cd case is broken, and the disc is used and the extra bit for the front was in a clear carry bag.
I’m thinking of leaving this feedback what do you think, leave feedback or wait and see what ex-audio say
Worked 5m,don’t buy,read reports,mp3car.com,under display,Lilliput in-dash 7”
Old 08-04-2005, 05:04 AM   #357
What software? there's only software for the touch screen but you don't have to load that for the unit to run.
Old 08-04-2005, 07:17 AM   #358
MaleBuffy's Avatar
He means Firmware....
MaleBuffy is offline   Reply With Quote
Old 08-04-2005, 07:56 AM   #359
OK I understand, so if they have a fix could we flash it instead of returning it to Hong Kong?
Any body know how to get it back to factory setup?
Old 08-04-2005, 08:06 AM   #360
Talk to bran55. Didn't he have a similar issue?
3rd Time's the Charm??? Mercury Cougar Dash Lilliput antimatter Fabrication 23 08-07-2006 01:21 PM
FS: 7" In Dash Lilliput (Both Parts) Avalerion Classified Archive 4 06-28-2006 05:02 PM
FS : Car pc (mini-itx full + lilliput in dash 7") mph125 Classified Archive 2 03-18-2005 08:48 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
