Hello,
I endly finished to read this 30 pages post
I received my unit last week ( on thursday ), as I was N°6 on Ex-audio's payement list. I didn't had any duties taxes ( they used Fedex.... ), if I read well I'd be the only one here...
I've spent my week-end in connecting/unconnecting from my car as it's too deep for my DIN, and when enter it at maximum, screen can't open correctly because of the air grid next up to the DIN which come a little bit out of the dashboard... ;(
To speak a little bit of your major pb :
1) my motor still work for the moment, as I've tried to open/close it a couple of times. Some time, when it has no video/VGA input and I open it, screen open at maximum ( then touch the air grid ), beeps twice and close after 2 seconds. The only ways I founded to fix this up were : a) unplug it, the replug it, and if it doesn't work b) put it in radio mode ( either with the button; or with the RC, when button doesn't work.... )
2) Radio mode works fine,
3) my only problem is with the "Down" button ( or "Scan -" on the RC ) when the screen is opened... it only works about 2 times for about 100 pressures ;(( As I often disconnect the lilliput, it doesn't remember the old screen position, and then adjustement is nearly impossible )
I wrote to Stephen Sin which one offered me to send me another RC, but I explained him that it doesn't seem to be a remote problem, as screen button (Down) panel doesn't work too... I'm waiting his answer now.
( I encountered scaling pb with the TSK, but I've updated the drivers today, and I'll try a calibration later.... )..
I didn't tried Video input, that's for tonight
but, for the moment, only sound (no vid ) on Video1 works fine.
VGA+sound works fine too.
Else:
At the beginning I had connected the Auto antenna wire and the only thing it could has messed up could be this "down button"...
For now POUR and Auto Ant aren't connected.
BATT is connected to permanent positive and VCC is conected to ignition power.
I didn't tried TV as TV antenna are nearly unfoundable here in France, I need to order it elsewhere.
VGA works perfectly with my laptop as I don't have CAR PC for the moment...
The only way for me to the screen to open correctly ( IFO open-> Beep.Beeep-> then close 2 sec after ) is to put the unit in radio mode before stopping the car.
Reflectivity is an horror!!! nearly impossible to see correctly the screen on day! I need a solution for this.
Hoping I could help you.
Sorry for my bad english, as I'm french as you could have read.
Forden
