Old 07-21-2005, 11:51 PM   #91
BikeBoy24 is on a distinguished road
Actually, I just noticed that in the specifications, the input voltage is 10.8-13.8V. Does this mean there is built in circuitry to regulate the voltage?
I just want this screen to last. Pretty expensive investment!
BikeBoy24 is offline   Reply With Quote
Old 07-22-2005, 12:54 AM   #92
bran55 is on a distinguished road
Quote: Originally Posted by BikeBoy24
Thanks for the quick replies.
I'm curious, why is the fuse on the switched power yellow VCC? Shouldn't it be on the constant power red batt?
Just to make sure, I connect my power supply wire to the red wire (BATT)? But that wouldn't be too good...the monitor would lose its settings everytime the computer shuts off wouldn't it?
i never figured out why there is a fuse there makes me wonder too...but the batt wire shud b connected to a constant source of o power and the yellow one is the ignition (tells when to shut off/come on)
bran55 is offline   Reply With Quote
Old 07-22-2005, 01:37 AM   #93
bmoney03 is on a distinguished road
Its the other way around. Yellow is constant and red is switched. Thats y yellow is fused. Also can u guys post some pics im really interested in this.
One more ques: does it have and rca audio out? Thanks
bmoney03 is offline   Reply With Quote
Old 07-22-2005, 01:46 AM   #94
Yes, there are RCA audio outs. I will try to take some pics tomorrow before I install it.
I don't think Yellow is constant (at least not on the lilliput harness). Even in the manual, it says Yellow is switched, and Red is constant. On a standard harness, it is the other way around.
bran55, did you wire it up to an adapter? Did you just use the same colours? If so, Lilliput labeled the wires wrong.
Old 07-22-2005, 02:51 AM   #95
WEll if u hook it up the other way around it just wont hold its memory. SO in that case just switch the wires around. Come to think of it i dont think it will even turn on if the wires are switched. But it would not make any sense for a switched wire to be fuses. U would want the constant to be fused. HMMM
Old 07-22-2005, 07:11 AM   #96
That's true. It's not drawing any large current from the switched line. Unless, it uses the red wire as a battery backup, and draws the full current from the switched line. That would be weird. I guess I will have to try and find out.
Old 07-22-2005, 07:36 AM   #97
Colatabajonies is on a distinguished road
Touchpanel
is anyone else having problems with the touch screen being flakey? Like getting it to work and then all of a sudden stop working? My computer see's it now as a "generic USB hub," when it used to see it as a touch screen? wtf is going on? any suggestions?
Colatabajonies is offline   Reply With Quote
Old 07-22-2005, 08:22 AM   #98
Raw Wave
kickercivic1's Avatar
kickercivic1 is on a distinguished road
reinstall the driver maybe?
kickercivic1 is offline   Reply With Quote
Old 07-22-2005, 10:38 AM   #99
MaleBuffy's Avatar
MaleBuffy
Whats wrong with the TS?
MaleBuffy is offline   Reply With Quote
Old 07-22-2005, 11:46 AM   #100
jmattwood is on a distinguished road
7" In-dash
Mine arrived on Saturday by UPS.
Hooked it up last night Radio worked, VGA worked, TV worked...........motor will not close the screen. It stops it the horizontal position.
jmattwood is offline   Reply With Quote
Old 07-22-2005, 11:57 AM   #101
MaleBuffy's Avatar
MaleBuffy
So they didnt fix that afterall, or they just released it and left it to luck....?
Old 07-22-2005, 11:59 AM   #102
Hmm.
A little disappointing, I have to confess.
Old 07-22-2005, 02:57 PM   #103
Raw Wave
great to know this now. I ordered mine last night.
Old 07-22-2005, 05:55 PM   #104
MaleBuffy's Avatar
MaleBuffy
LOL, well lets hope you receive a better screen!
Old 07-22-2005, 06:51 PM   #105
Cravex7's Avatar
Cravex7 is on a distinguished road
Angry
Hi,
I also have one of these monitors, I recieved it on wednesday and have been really happy with it until today when the motor jammed. It's currently stuck half open, I would advise anyone buying one to hold off for the time being. I have emailed ex-audio, I will also be contacting lilliput and will post if I get a satisfactory answer.
Cravex7 is offline   Reply With Quote
3rd Time's the Charm??? Mercury Cougar Dash Lilliput antimatter Fabrication 23 08-07-2006 01:21 PM
FS: 7" In Dash Lilliput (Both Parts) Avalerion Classified Archive 4 06-28-2006 05:02 PM
FS : Car pc (mini-itx full + lilliput in dash 7") mph125 Classified Archive 2 03-18-2005 08:48 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
