02-07-2007, 04:25 AM
#1201
Banned
The price is cheaper,only us$350
02-10-2007, 12:56 AM
#1202
I've only tested my lilliput on a bench, but it seems to work great (minus the issue I've been discussing in this thread).
Anyway I am about to install my unit and I have two power cables an ACC cable which is fused and a BATT cable which isn't. When I tested the unit with a DC power supply I just hooked them both to +12V. I was wondering if I should hook them both directly to the battery or do I need to hook one to the line that only turns on with the car. Thanks for your help.
-Ross
02-10-2007, 02:02 AM
#1203
Unless you want to have to turn the unit on and off every time, attach the ACC cable to a switched source. There is a menu option to set the unit to automatically turn on. It's extremely convenient.
02-11-2007, 01:27 PM
#1204
Quote: Originally Posted by Ste_nova
mines still going strong... 4 months now... in use every day
mines just died  cracked the tilt cog
2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch, bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
02-11-2007, 05:44 PM
#1205
I have connected lineout to the amplifier but don't works. It must activate it from some part? I must activate it before???
Sorry for my english i'm italian
Marco
02-11-2007, 09:50 PM
#1206
Marco
I had the same problem. Line-out worked for the TV tuner but did not switch the VGA Line-In when the VGA source was selected. In the end, I said **** it and ran the line-out from my PC straight to my head-unit. I actually prefer it like that now because I can turn the display off while I'm driving to satisfy Australian law (can't have an LCD "video" display visible by the driver while driving) if I want to.
02-12-2007, 02:36 PM
#1207
My Review of the Lilliput
Hello All,
This past weekend I bought and had installed the LCD that is available from Geeks.com, which I believe is basically the Lilliput 7".
So far it is working great and I am liking it. I have post a little review and pics under "Show off your Project Thread".
You can check it out there. I hope everything continues to work fine.
Please let me know if you have any opinions, commments, suggestions.
This is my first project and just the beginning. As I acquire more equipment, I will try to update
02-13-2007, 12:54 PM
#1208
Is the option to have it automatically turn on available if I connect ACC to a switched source? Also what do I connect the reverse to? By default do I want to ground the cable, set it to 12V, a switched source or leave it floating? I don't know if my car has a line that changes when the car goes into reverse. Thanks for your help.
-Ross
02-13-2007, 11:34 PM
#1209
Hey GunsandRoses
When you place your car in reverse, your reverse lights come on. If you tap into that fuse/wire, you will have what you need.
I've got the same screen and have been having none of the severe problems like those in the beginning of the thread.
However, I do not have the instruction manual and cannot figure out how to set the clock. Any suggestions?
Cheers
02-15-2007, 08:20 AM
#1210
OK, I have a problem.
I was doing some work on the test bench today and reversed the polarity accidentally through my head unit (Lilliput 7 inch in-dash thing). I've replaced the external blade fuse and tryed powering it up again and the fuse keeps blowing on me. I also reversed the polarity through my Computer at the same time and replaced the fuse on the M2-ATX controller and it now works fine.
I've read in other threads that some Lilliput screens have a secondary fuse. I opened the case up and had a look, and can't see anything that looks like a fuse. Could there be a 'dummy diode' there somewhere for idiots like myself who chose to accidentally wire things backwards? Would would I be looking for?
03-06-2007, 02:53 AM
#1211
thank you guys for all posts.. i think you saved me a lot of headache by not buying one of these units and paying the extra money for a xenarc! 700idt on the way
03-10-2007, 12:18 AM
#1212
It makes me EXTREMELY happy to know that this thread saved even one soul from the evil clutches of this horrendous $400 pile of crap.
03-12-2007, 09:18 AM
#1213
i'm sure i've seen some pics of the inside of this unit somewhere (someone was fitting it in a different case???) anyone know the link to those pics?
03-13-2007, 03:20 AM
#1214
Are you talking about me???
Look at my links in my signature.
03-13-2007, 09:33 AM
#1215
i hadnt seen yours before... i need a pic of the switch that the screen housing pushes down on when it's fully out
| Thread Tools |
| Display Modes |
Linear Mode
