Old 03-13-2007, 06:50 PM   #1216
coucouillu's Avatar
coucouillu is an unknown quantity at this point
Quote: Originally Posted by Ste_nova View Post
i hadnt seen yours before... i need a pic of the switch that the screen housing pushes down on when it's fully out
Sorry but i haven't any.
These switch are a piece of crap!!!
coucouillu is offline   Reply With Quote
Old 03-26-2007, 10:06 AM   #1217
Blue_Stivo is an unknown quantity at this point
I need a replacement for that switch as it has broken on mine so the screen only comes out and doesn't turn up
I think I have a picture up in this thread. http://www.mp3car.com/vbulletin/lcd-...01-tv-c-t.html
The switch is labeled 'K1' in the bottom left of the picture.
I agree with coucouillu though. That particular switch is extremely weak.
Blue_Stivo is offline   Reply With Quote
Old 04-24-2007, 03:45 AM   #1218
gera is an unknown quantity at this point
Hello,
after reading all negative posts here i still decided to give it a try...
So got one used on ebay... However the guy forgot to throw the owner's manual in and now i'm having some problems with the wiring and setup.
Can somebody give some advise on:
- power wires. on my unit I have one Red marked ACC with fuse on it and one yellow marked BATT. Where do they go?
- what are NE wires for?
- what is AUTO ANT? power antenna?
- how would they mark the dimmer wire - it seems there is no one on my unit
- how do i setup the clock
thanks in advance
gera is offline   Reply With Quote
Old 04-25-2007, 08:51 AM   #1219
you can find the manual PDF here
http://www.brashimports.com.au/GL701.pdf
Old 04-25-2007, 11:01 AM   #1220
Thank you! Spent good time googling but couldn't find it...
It's helpful, my unit looks quite different though.
Old 06-05-2007, 02:13 PM   #1221
DCU1976's Avatar
DCU1976 is on a distinguished road
Serial numbers for newer units
Does anyone know the serial numbers for the newer units? Here is a listing I have for the new and old:
The serial number to the old unit: 11701TV0070
The serial number for the newer unit: 701TV83451121 <-newest serial I could find.
Also what it the best way to bench test these units on a Computer power supply? Hook both yellow and red wires to the 12v on a PC power supply, and ground to the black wire?
DCU1976 is offline   Reply With Quote
Old 09-19-2007, 01:27 AM   #1222
lyzybear is an unknown quantity at this point
You can try if you just want to test the screen.
I tested mine on a used car battery. It shows 1.5A when screen is working, 0.7A when screen is working without signal, 0.3A when it stand-by. That should be OK if you use a computer power supply. BUT, if you connect your unit which has amp and radio with speakers (I'm talking about GL701), forget computer power supply.
lyzybear is offline   Reply With Quote
Old 10-11-2007, 01:48 PM   #1223
coucouillu's Avatar
Hi all,
I am looking for donation about this product.
I am looking for broken units in order to finish hacking this unit.
The problem is that I only hacked the first models and many evolutions have been made since this time.
Thank you for your answers..
Old 10-12-2007, 02:05 AM   #1224
SoloconDeus's Avatar
SoloconDeus will become famous soon enoughSoloconDeus will become famous soon enough
Question
***I missed klast night I put th3 wrong forum*****
SoloconDeus is offline   Reply With Quote
Old 10-12-2007, 07:30 AM   #1225
businessservice is an unknown quantity at this point
Cou I have a broken one somewhere in my workshop, I am open to offers
Business Services UK a provider of financial and web related services
businessservice is offline   Reply With Quote
Old 10-12-2007, 06:08 PM   #1226
coucouillu's Avatar
Hi businessservice,
I appreciated your help. I sent you a private message.
Old 10-21-2007, 04:01 PM   #1227
coucouillu's Avatar
Lilliput Hack
I need some help to understand LILLIPUT signal beetween screen and unit main board.
It seems loke I2C cpmmonication.
For each case, these are 2 signals on 2 buses. Like SCL and SDA
Here is the syntesis I made on it :
Old 01-07-2008, 08:38 PM   #1228
leosalles is an unknown quantity at this point
FM radio on Lilliput
I´m having dificult to setup the FM function of my Lillioput GL701, someone know how to store a station and how to call a stored station saved in two digits (like 10,11,12,....)
Thank you.
Carputer on Honda Civic 2005
P 2.8 -2 GB Ram - Toshiba Satellite - A45 S121
GPS - DVD-ROM
Lilliput touchscreen
Road Runner
leosalles is offline   Reply With Quote
Old 01-23-2008, 03:01 PM   #1229
coucouillu's Avatar
Does any one have a broken/unused indash lilliput?
Old 02-07-2008, 12:53 PM   #1230
tkd_guy90 is an unknown quantity at this point
Exclamation gear problems?
I've had the Lilliput in-dash 7" model for half a year now. Everything works just fine except when I push the eject button for the screen to come out. I push the button, it slides out horizontally like normal then starts to go up and just stops. I haven't taken it out of the car yet and my uncle who's an electrician said it doesn't look like the motor is going out, just something is stuck in the gears. Anyone else have this problem? I tried the remote "up" button, and the up button on the screen and it won't go up but Im still getting video, audio from my pc. the radio still works, and the screen goes back in just fine. I don't hear any clicking or any noises that don't sound out of the ordinary.
tkd_guy90 is offline   Reply With Quote
Advertisement Sponsored links
3rd Time's the Charm??? Mercury Cougar Dash Lilliput antimatter Fabrication 23 08-07-2006 01:21 PM
FS: 7" In Dash Lilliput (Both Parts) Avalerion Classified Archive 4 06-28-2006 05:02 PM
FS : Car pc (mini-itx full + lilliput in dash 7") mph125 Classified Archive 2 03-18-2005 08:48 AM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
