Old 07-28-2005, 12:52 PM   #16
Replacement Cable
I was wondering if you found a source for the replacement cable for the 8" Touchscreen? Mine had a short in the DIN connection and I had the bright idea to just cut out the DINs and wire direct, so I peeled back the coating on the PC side of the DIN and logged the pinout and proceeded to do the same on the monitor side. I just whacked it off then peeled back the coating to find (red/blk/brown-red/blk/brown-red/blk/brown) so now i'm screwed. If someone has the pinout for the special plug that plugs into the monitor (i would be very thankful) then i could maybe ring the wires to determine the proper connection, but at this point I'm looking for a replacement.
dukman is offline   Reply With Quote
Old 07-28-2005, 02:50 PM   #17
You need the pinout on the cable that attaches directly to the monitor? the 24 pin or whatever it is? How are you going to connect to the monitor, VGA, S-Video, or composite? Let me know and I will try to ring it out tonight.
J's89 is offline   Reply With Quote
Old 07-28-2005, 10:28 PM   #18
lilliput 8"
I am trying to run VGA and touchscreen, I chopped the DIN connectors off the special vga/ts cable because it kept losing connection between them. I had to apply constant pressure (push them together) to keep the signal, as soon as I would relax the screen would say "no vga signal", anyway what I need to fix my cable now is the pinout from the white 26 pin monitor plug to the 15 pin vga and usb, I'm assuming only 9 of these are used since the DIN plug was only 9 pin, Thanks for your help J's89
Old 07-29-2005, 07:18 AM   #19
I will work on this for you this weekend. It shouldn't be very difficult. I'm going to post the connections between the 26 pin and the 9 Pin. The connections between the 9 pin to the USB/VGA are already posted, and I will be replying via my cell phone internet. So just refer back Snootch's post for the last half of what you need.
Old 07-29-2005, 08:53 AM   #20
Thank you for your help
Old 08-02-2005, 05:56 PM   #21
How about that pinout..........Anyone?
Old 11-08-2007, 03:15 PM   #22
Quote: Originally Posted by Snootch View Post
Since the pins on the VGA connector are numbered, i'll give you the pinout assuming on the 9-pin DIN connector, the two pins side by side are at the bottom, and pin#1 is top left, so the pins are like:
12 3
4567
89
VGA pin#1-----DIN pin #1
14----2
13----3
2----8
3----9
Does someone know if this DIN connector is a good available standard one ?
Someone knows the exact type (or ordering code ) ?
Would like to create my own custom cable with all in one cable (audio for the screen speaker, vga , touch usb, power) and long enough to go from the front of my A4 to the back (below the rear seat)
BartDP is offline   Reply With Quote
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 119 10-08-2008 05:37 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 06:26 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 05:38 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 08:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 04:37 AM
