The MP3car.com Store
Thread Tools Display Modes
Old 07-28-2005, 12:52 PM   #16
My Photos: (0)
Replacement Cable
I was wondering if you found a source for the replacement cable for the 8" Touchscreen? Mine had a short in the DIN connection and I had the bright idea to just cut out the DINs and wire direct, so I peeled back the coating on the PC side of the DIN and logged the pinout and proceeded to do the same on the monitor side. I just whacked it off then peeled back the coating to find (red/blk/brown-red/blk/brown-red/blk/brown) so now i'm screwed. If someone has the pinout for the special plug that plugs into the monitor (i would be very thankful) then i could maybe ring the wires to determine the proper connection, but at this point I'm looking for a replacement.
dukman is offline   Reply With Quote
Sponsored Links
Old 07-28-2005, 02:50 PM   #17
My Photos: (0)
You need the pinout on the cable that attaches directly to the monitor? the 24 pin or whatever it is? How are you going to connect to the monitor, VGA, S-Video, or composite? Let me know and I will try to ring it out tonight.
J's89 is offline   Reply With Quote
Old 07-28-2005, 10:28 PM   #18
My Photos: (0)
lilliput 8"
I am trying to run VGA and touchscreen, I chopped the DIN connectors off the special vga/ts cable because it kept losing connection between them. I had to apply constant pressure (push them together) to keep the signal, as soon as I would relax the screen would say "no vga signal", anyway what I need to fix my cable now is the pinout from the white 26 pin monitor plug to the 15 pin vga and usb, I'm assuming only 9 of these are used since the DIN plug was only 9 pin, Thanks for your help J's89
Old 07-29-2005, 07:18 AM   #19
My Photos: (0)
I will work on this for you this weekend. It shouldn't be very difficult. I'm going to post the connections between the 26 pin and the 9 Pin. The connections between the 9 pin to the USB/VGA are already posted, and I will be replying via my cell phone internet. So just refer back Snootch's post for the last half of what you need.
Old 07-29-2005, 08:53 AM   #20
My Photos: (0)
Thank you for your help
Sponsored Links
Old 08-02-2005, 05:56 PM   #21
My Photos: (0)
How about that pinout..........Anyone?
Old 11-08-2007, 03:15 PM   #22
Vehicle: 2007 Audi A4
My Photos: (0)
Quote: Originally Posted by Snootch View Post
Since the pins on the VGA connector are numbered, i'll give you the pinout assuming on the 9-pin DIN connector, the two pins side by side are at the bottom, and pin#1 is top left, so the pins are like:
12 3
4567
89
VGA pin#1-----DIN pin #1
14----2
13----3
2----8
3----9
Does someone know if this DIN connector is a good available standard one ?
Someone knows the exact type (or ordering code ) ?
Would like to create my own custom cable with all in one cable (audio for the screen speaker, vga , touch usb, power) and long enough to go from the front of my A4 to the back (below the rear seat)
BartDP is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 115 08-15-2008 03:38 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 06:26 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 05:38 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 08:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 04:37 AM
Sponsored Links
Ad Management by RedTyger
