Old 07-14-2005, 07:12 PM   #1
HELP: 8" Lilliput TS Owners- need a favor
***Edited***
I broke a pin off of the 15 pin connector coming off of the 9 pin mini-d that connects to the monitor. Like an idiot, I cut the plug off to replace it without ringing out the other wires first. If someone could ring out the 9 pins and tell me where their position on the VGA and USB plug, I would GREATLY appreciate it!!!!
I've called Digitalww 5 or 6 times and left messages and they never call back, and also sent an email, no response there either.
J's89 is offline   Reply With Quote
Old 07-14-2005, 08:02 PM   #2
Jesus Freak
antimatter's Avatar
bumber...good luck
antimatter is offline   Reply With Quote
Old 07-14-2005, 08:19 PM   #3
MySQL Error
jcdillin's Avatar
why not just check with digitalww and see if he has a replacement cable?
肚子笑痛了
S60 Install
jcdillin is offline   Reply With Quote
Old 07-14-2005, 09:05 PM   #4
Because I'm racing Sunday, and need to datalog/ tune. If I can't find what I need or make it work I will. I did find some help here: http://www.tmz.com/wrx/lilliputlcd.html
I'm going to have to sort through it and see if it works. I'm checking on how a 9 Pin connector is numbered now!
Thanks for hte replies though.
Old 07-14-2005, 09:08 PM   #5
Calm
Down
Or
Get
A
2
Week
Vacation
-Love
The
Forum
Policeman
Wiredwrx's Avatar
Quote: Originally Posted by J's89
I broke a pin in the 15 pin converter (15 pin > 9Pin/USB) to the monitor. The Monitor would power on and show the "NO VGA SIGNAL". I cut the VGA off thinking I would simply solder a new one on. It's not quite that easy. I search and read all of the VGA pinouts on the web, but since I don't know which wire performances which function they're not very helpful. So Cut a VGA ext ention and color matched the wires, with the exception of two that didn't match. Plugged it in, and tried with the wires on both of the others but no dice. Does anyone have a color to pin diagram for this set of connectors?
Its an 8" if they're different!
If you post the PLEASE give me some terms, cause I tried!
Thanks!!!
THere is no standard wire color, only standard pins. Just cutting and connecting like colors is a VERY BAD IDEA in general. You need to "beep" out the wires and pins.
Besides, what did you break, and what did you cut and connect?
Michael
...I love the French language...especially to curse with...Nom de Dieu de putain de bordel de merde de saloperies de connards d'enculés de ta mère. You see, it's like wiping your *** with silk, I love it. www.yellinlawoffice.com
Wiredwrx is offline   Reply With Quote
Old 07-14-2005, 09:21 PM   #6
WRX? Is that a coincidence or is that your site I found? If it is, many thanks-very helpful.
I did ring out the 9 Pin connector- I'm not sure how it's numbered, But assuming it's
Top to bottom left to right:
1 BK
2 BR
3 R
4 OR
5Y
6 GR
7 BL
8 Purple
9 GY
I'm still lokking for the layout of the numbering of a 9 pin connector. After I find that I should be able to figure it out with the diagrams in the link. If you know of a simpler 9>15 pin diagram please send me toward it!
Old 07-22-2005, 11:03 PM   #7
TTT..for the weekend crowd. If any one has time this weekend to help me figure this out it would be GREATLY APPRECIATED. A week without the carputer/ music sucks!
Old 07-24-2005, 12:15 AM   #8
That didn't work out. Can someone please ring these out on their monitor for me?
Old 07-26-2005, 10:03 AM   #9
Ttt
Old 07-26-2005, 05:29 PM   #10
MySQL Error
jcdillin's Avatar
ok what pins do you need rung out?
肚子笑痛了
S60 Install
Old 07-26-2005, 06:20 PM   #11
Snootch's Avatar
Since the pins on the VGA connector are numbered, i'll give you the pinout assuming on the 9-pin DIN connector, the two pins side by side are at the bottom, and pin#1 is top left, so the pins are like:
12 3
4567
89
okay, VGA pin#1-----DIN pin #1
14----2
13----3
2----8
3----9
Hope this helps..
WORKLOG
VIA SN18000/1Gb GEIL PC3200/100Gb 2.5"HD/8" Phylon TS/BU-353 GPS/Powermate/M2-ATX PS
Webpage
Snootch is offline   Reply With Quote
Old 07-27-2005, 10:35 AM   #12
JC
I needed the pins from the barrel connector to the VGA cable, but Snootch hooked me up. Now all I need is the USB to Barrel or VGA whichever it connects to. Thanks for the help guys!
Old 07-27-2005, 01:37 PM   #13
Snootch's Avatar
USB pinout:
Looking at the USB connector with the logo on top (white part on bottom)
the 1st pin(left to right) goes to barrel pin#6
2nd USB pin to barrel pin#4
3rd USB pin to barrel pin #5
4th USB pin to barrel pin #7
USB and barrel shield also connected to VGA pin#6
all connector shields are connected together.
Hope this helps as well..
WORKLOG
Webpage
Old 07-28-2005, 12:13 AM   #14
Thanks again Snootch. You da man.
I got the monitor wired up and it works. I can see the splash page, and the status bar while the computer loads Windows, but then the screen goes blank, and it gives me the "NO VGA SIGNAL" message. Any ideas? That's what it was doing originally, when I found the broken pin, so basically I'm back to where I started.
Old 07-28-2005, 09:03 AM   #15
Alright, I tried the screen with my X Box and it worked fine off of the RCA's. I checked the computer with my home monitor and it works fine. So the problem lies between the barrel connector and the VGA cable that connects to the computer. I don't understand why I can see the splash page and boot screen and then it goes blank. Does this mean Windows is not "seeing" the monitor?
FAQ: Everything you need to know about your Lilliput hevnsnt LCD/Display 123 11-06-2008 07:05 PM
xenarc first impressions, tried lilliput before emdzey01 LCD/Display 7 06-09-2005 07:26 PM
Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc, Lilliput, Xenarc voidunknown LCD/Display 88 09-15-2004 06:38 PM
Lilliput touchscreen problems -- Need Help BrUTaL LCD/Display 1 08-20-2004 09:41 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 05:37 AM
