Old 07-15-2005, 06:19 AM   #1
audio noise when screen is on
hey all ive got a new model square lilliput. and when i turn the screen on i get real bad crackling and noise coming through my speakers while the computer boots. which is cause by the screen cause if i put the screen into standby while its booting the nooise is virtually all gone and once its booted and the audigy takes control of the audio ALL the noise except a tiny bit of alternator whine is gone. but what partof the screen could be causing all this noise? could ti be something to do with the power egg? ive got a regulated 12volt supply in the car should i try cutting off the egg and wiring it to this alternate supply (its a big job thats why i ask) or is there any other solution?
Dave_Perth is offline   Reply With Quote
Old 07-20-2005, 09:01 AM   #2
anyone?
Old 07-22-2005, 05:58 PM   #3
It sounds like you have grounding problems my friend, i had the same problem.. resolved it by running all power and grounds to a common point.(computers, screen & amps)
Also one of my Amps was amplifying the noise. (was fine with the car radio!! but when i started using a pc and screen i got loads of noise) I swapped it for an Infinity amp. It now works perfectly
I tried a different regulator and it made a slight improvement, but not much.
HWExtreme is offline   Reply With Quote
Noise on audio from laptop pip Laptops, Tablets, UPMCs, etc. 6 11-24-2006 08:09 PM
Audio problems, Epia Sound, and FAQ stuff gothate Newbie 2 06-16-2005 05:04 PM
Carputer audio Noise michaelrj9 Car Audio 3 05-17-2005 09:32 PM
Troubleshooting: NOISE RedGTiVR6 Car Audio FAQ 0 03-26-2005 11:31 AM
Audio noise, only with Lilli LCD on. muldrick LCD/Display 7 08-11-2004 07:45 AM
